Engines for SR on Amphibs.
Posted: Fri Feb 17, 2012 11:27 pm
Don,
I plan amphibs after a year or so on wheels. I have an "Lyc-Con" built
IO540-C4-B5, special pistons, gear coatings, flow balanced, and a little
nitrous oxide for the mountain lakes and places like the west side of
Vancouver Island. The engine has 8+ hours on the test stand and exceeds
my expectations for power. Fuel burn also exceeds my expectations but for
the way I plan to use the SR fuel is the least of my concerns. I plan on
flying off rough water and getting on step quickly is important to me as to
not destroy the airframe from the pounding. My float experience tells me you
can't have too much HP. Where and how you plan on using the airplane should
help decide your engine requirements.Where are you planning to fly? How
float experienced are you? How heavy do you plan to fly? What type of
weather? Here in the Pacific Northwest marginal VFR is the norm for part of
most summer days. I rejected the M14 for two reasons, first weight and
second my lack of my design/construction skill to adapt this engine to the
SR.
Al Paxhia SR26
To: (Murphy Rebel Builders List) <murphy-rebel@dcsol.com>
Sent: Wednesday, October 11, 2000 7:02 PM
Subject: Engines for SR on Amphibs.
SR.
Al Paxhia SR26
*---------------------------------------------------------------------------I have been coming home from building and reading the discussion on SR
engine choice with interest. The discussion to date has focused mostly on
power plants for the SR on wheels.
I would like to hear what builders who are planing on flying floats and
especially amphibs are considering for an engine.
I have a Zenair 701 with a 912. Great land performance. Only acceptable,
when loaded, amphib performance. It is certainly an understatement to say
that engine selection is vital to getting good performance out of an
aircraft on amphibs.
Presently my partner and myself see two main possibilities.
A Lycoming IO-540 in the 300 HP range or the M-14P with it's 360 HP
(assuming that Daryl approves and comes up with an installation for the
M14P)
I would like to hear what other SR amphib builders are thinking.
Don Boardman
Rome, NY
SR 130
