Thanks very much for the feedback Ted. I thought someone must
have had the same thoughts about it that I did. Should make the wing
job a little simpler. Now I only have to face removal of the elevator
to perform the tall plane mod as well.
Roger K
On 1/3/2009 8:34 AM, tedwaltman@i1ci.com wrote to rebel-builders:
-> Hello Roger,
-> The service bulletin you refer to is now located at this link:
-> http://www.murphyair.com/murphyair/Airc ... NG_TIP_MOD.
-> pdf
-> I did this mod on my Moose last year in a similar fashion to what Scott
-> describes below--just removing enough rivets to carefully insert the new
-> angle. I already had the end doubler in place. Note: This service bulletin
-> is probably more important for those folks who have the newer, wider,
-> aileron tip weights which of course place more stress on the outer aileron
-> hinge attach point. I have the older ailerons with the original style tip
-> width/weights.
-> Ted Waltman
-> -----Original Message-----
-> rogerk@dcsol.com
-> Sent: Wednesday, December 31, 2008 6:01 PM
-> Subject: [rebel-builders] RE: SR / Moose wing tip mod service bulletin
-> I've noticed the same thing on mine. Did anyone ever have an answer to
-> this question? It looks like the specified doubler already exists.
-> Roger K
-> On 4/13/2005 11:31 AM, SA@MWUTAH.COM wrote to REBEL-BUILDERS:
-> -> I am looking at my fast build Moose wings and they already have a
-> -> large aluminum doubler in the aft tip rib position that the wing tip
-> -> service bulletin calls for W-1030. Looks like you could just remove
-> -> a couple of rivets to cut off the rib flange and slip in the
-> -> stainless steel angle W-1031, no need to completely remove the
-> -> existing doubler or add the new aluminum one.
-> -> Has anyone else done this mod or upgrade to fast build wings yet?
-> -> Scott
-> -> Moose 174
-> http://www.murphyair.com/SUPPORT/PDF%20 ... %20MOD.pdf
-> List archives located at: https://mail.dcsol.com/login username "rebel"
-> password "builder"
