CC100 sleeve INSIDE the cockpit? Rebel Question
Posted: Fri Feb 17, 2012 11:27 pm
by hibbs
Thank Wayne, I am cutting the sleeves and it does take some work to cut
them straight. Any idea why they suggest 2 sets on each inboard end (1"
+ 1/2" vs 1 1/2")? Since it is difficult to cut, I'd just as soon cut
only 1 unit 1 1/2" long.
Best Regards,
Scott Hibbs
hibbs@pacifier.com
Your following message has been delivered to the 164 members of
the list murphy-rebel@dcsol.com at 09:30:53 on 8 Oct 2000.
I don't see any reason not to cut just ONE sleeve, to fill the exact
distance you need. They are suggesting 1" plus 1/2" in your version of the
manual, as I believe these are the sleeve widths they are supplying precut.
The old way (as it sounds you have) was to supply a length of 2" I.D. tube
and you cut each sleeve at the required width.
Are you one of the builders that is working from an "updated" manual and not
the one that came with your kit?????? If so, you may be adding some
confusion to the "game"!
Sent: Saturday, October 07, 2000 11:40 PM
Subject: Re: CC100 sleeve INSIDE the cockpit? Rebel Question
Best Regards,
Scott Hibbs
hibbs@pacifier.com
