Lycoming O-320-A2B available..
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:03 pm
Is anyone on the list considering building up your own O-320 x 150HP.... to
learn and save some labour dollars? And doesn't want to roll the dice or
play CRAPS.. buying someones TBO'd engine?
If you are send me an email directly ASAP, before I start parting this out
on Ebay. oifa@irishfield.on.ca
I have a disassembled / cleaned / NDT inspected (by certified facility -
ATC) O-320-A2B Narrow Deck.... pretty much complete including freshly
chromed to std size cylinders with the valves and guides done and installed
/ pistons c/w new rings already gapped and installed. (Cylinder chroming /
rings / valve work worth $2200 alone... not counting the $960 for
Disassembly, Clean and inspect)
I picked this and the remainder of my engine stuff up from ATC yesterday.
Still going thru it all to put together a complete engine for someone to
build up. If anyone is interested let me know. As like I said it's going to
go piece meal on Ebay if nobody wants a package. Looking to get my $3480 for
current work out of this and something fair in the way of $'s for the
original core. Have perfect cam, new lifter bodies etc to go with it. Have a
carb you can rebuild or for extra money one that's already overhauled ready
to go. Crank flange is straight and current bearing surface wear is
measuring about 2 thou from STD size. Has some pitting on the thrust bearing
area, but should come clean enough to use with a 10thou grind and renitrate.
Accessory case has provision ports for vacuum pump / governor / fuel pump if
you wanted to use any of those items.
