[rebel-builders] Window vents CC-3251
Posted: Sun Feb 19, 2012 8:03 pm
Be sure to clamp a hunk of wood... or get some brave sole to hold it for you
while you hole saw the opening. Does a much better job that way.
Sent: Wednesday, November 19, 2008 12:53 PM
Subject: Re: [rebel-builders] Rebel Instrument Panel - Dynon D180
I put the same ones in my window and like the simplicity - the only thing I
will caution you on, is to make sure when you cut the window that you
don't
cut it too big. The first one is a little sloppy and so it vibrates out or
open while the second one I sanded the opening to the right size to get
just
the right amount of friction.
Jim R333
On 11/19/2008 12:14 PM, "Walter Klatt" <Walter.Klatt@shaw.ca> wrote:
No, mine close flush, so no interference when the window is down, and you
can rotate them for direction. I think you are talking about the smaller
ones. Mine are the larger 3+ inch ones.
Dalgleish
Sent: November 19, 2008 9:02 AM
Subject: RE: [rebel-builders] Rebel Instrument Panel - Dynon D180
Hi walter the snap vents I looked at spin around to either face the
airstream or away from it but they never close. Is that what you have?I
don't want an open vent in the winter time. I still haven't gotten around
to installing a heater yet.
At 07:01 AM 11/19/2008 -0800, you wrote:
Drew, I just have the plastic snap vents in my windows, cheap and easy
install, and they work great. Can't imagine flying in hot summer weather
without them.
Dalgleish
Sent: November 18, 2008 9:08 PM
At 07:14 PM 11/18/2008 -0900, you wrote:
Thanks James My kit didn't come with any vents so I fly with the window
open or closed. Not the most comfortable solution. I've considered
putting
in cessna style wing root vents but those look like they'd be even
nicer.
by Drew Dalgleish
LOL Thanks everybody I'm going to go the simple way and leave the fancy
vents for the RV drivers. I'll get my darling partner in life to hold the
hunk of wood. She's so brave she has a hole in every finger as a sovenir of
drilling the tailcone wraps.
