Page 1 of 3
[rebel-builders] Rebel Amphib Height
Posted: Sun Feb 19, 2012 8:02 pm
by Rebflyer
My Rebel is 9"5" on the Amphibs. MAM 1800"s.
The Highest point is actually the Com antenna on the Cabin Roof. Tail is
about 9'4".
Curt Martin
N97MR
**************Get the Moviefone Toolbar. Showtimes, theaters, movie news &
more!(http://pr.atwola.com/promoclk/100000075 ... ?redir=htt
p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001)
by robert
My Elite on MFC 2200's is also just under 10' w/ the top of the rudder being the tallest point.
Cheers, Bob 612e
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Sent: Nov 17, 2008 12:46 PM
Subject: Re: [rebel-builders] Rebel Amphib Height
about 9'4".
Curt Martin
N97MR
Sent via BlackBerry by AT&T
by snowyrvr@mtaonline.net
Thanks, fellas; we're looking at a hanger with a 10' door so it sounds
pretty good. Craig
Original Message:
Date: Mon, 17 Nov 2008 21:06:22 +0000
Cheers, Bob 612e
about 9'4".
Curt Martin
N97MR
more!(http://pr.atwola.com/promoclk/100000075 ... 7/aol?redi
r=htt
mail2web.com
by rebflyer
Just as long as it's not a nose down ramp, which would make the tail higher going in the door. If you're pretty flat you're good to go.
    Curt Martin
From: snowyrvr@mtaonline.net <snowyrvr@mtaonline.net>
Sent: Tue, 18 Nov 2008 1:30 am
retty good. Craig
Original Message:
rom: robert@montanasky.us
heers, Bob 612e
rom: Rebflyer@aol.com
bout 9'4".
Curt Martin
N97MR
=htt
ail2web.com – What can On Demand Business Solutions do for you?
ttp://link.mail2web.com/Business/SharePoint
Posted: Sun Feb 19, 2012 8:03 pm
by Eric Fogelin
My Elite on Murphy 1800 amphibs is 10'-1" to top of the tail. The Comm
antenna on the cabin roof is nearly the same. The tail height can vary
depending on what angle you set your floats.
I set my floats at 1.7 degrees (top of float compared to bottom of main
cabin. Others are setting higher angles: 2, 2.5, 3 and 3+ degrees. The
greater the angle, the lower your tail (by quite a bit).
Elite 645E
Sent: Monday, November 17, 2008 10:31 PM
pretty good. Craig
Original Message:
Cheers, Bob 612e
about 9'4".
Curt Martin
N97MR
r=htt
mail2web.com - What can On Demand Business Solutions do for you?
http://link.mail2web.com/Business/SharePoint
Eric... have you tried getting your Elite to fly off the water yet @ only
1.7 degrees? Even at 2.3* hard to get them to part the surface as trying to
rotate the "wing" to get airborne will have you dragging the rear keel. 3 to
3.5* seems to work best and I've adjusted more than a few and always end up
at 3.3 to 3.5*'s
Sent: Saturday, November 22, 2008 7:35 PM
Subject: RE: [rebel-builders] Rebel Amphib Height
Elite 645E
pretty good. Craig
Original Message:
Cheers, Bob 612e
about 9'4".
Curt Martin
N97MR
r=htt
by Ken
Hmmm
So maybe 4.5 with the Mackenzie drooped leading edge then since it
lowers the wing angle of incidence about 1.5* ??
at 3.3 to 3.5*'s
Elite 645E
Quite possible Ken. I still drag my keels on some days while trying to horse
it off the water in less than 9 or 10 seconds..which of course makes the run
15 instead. With CYP Howard always said it was great at 2.3*... but then
when I sold it the new owner (with 30+ thousand hours) complained it
wouldn't leave the water without lifting a float as he couldn't rotate it to
climb out. We made it exactly the same as mine @ 3.4/3.5 and it was like
night and day. It jumped off the water... unfortunately it jumped thru a
soya bean field in July as well to end CYP's life! Bob White's Elite, in the
hangar, is on Clamar 2200's and I mounted it at 3.5*'s as well... and it
very quick off the water. He gets out just as short as I do with my Rebel.
I think Bruce Georgen is mounted at 4 or 4.5* with his Rebel. Don't think he
has the Angus cuff and he is happy with his performance as well.
I just can't see getting a Rebel or Elite off the water in any efficient
manner at only 1.7* throat angle.
Sent: Saturday, November 22, 2008 10:42 PM
Hmmm
up
at 3.3 to 3.5*'s
Elite 645E
by robert
Hmmm ... Perhaps the aft spreader bar needs to come fwd one bulkhead?
Bob, 612e
Date: Sat, 22 Nov 2008 22:51:14
Hmmm
up
at 3.3 to 3.5*'s
Elite 645E
That's a whole nudder story! lol .. but has nothing to do with dragging the
keels on rotation.
You only sink the rear spreader under if you start your take off run stick
back... if you start stick neutral and then back only after moving forward
the floats are up enough you can't turtle the rear spreader bar.
Sent: Saturday, November 22, 2008 11:04 PM
Bob, 612e
horse
run
he
Hmmm
only
3
up
at 3.3 to 3.5*'s
by Walter Klatt
Bruce's was at 3.5 degrees, which I thought was the largest angle anyone was
using at the time. Mine is still at 2.5. It has been my intention for a
while now to move it to 3* next time I have the floats off, but still
haven't done it. The other locals here are still using 2.5, too, although I
told them to try 3.
I also measured my tail height recently, and it is at 9 feet 3 inches. Does
that sound like a 2.5* angle? With the 360, I am getting off the water
pretty fast now, but what the hey, if it can be even better, I'll try it. I
still haven't tried it this year at a high elevation lake with a good load.
That will be the real test.
Did a flight out to the lake today, actually. Just installed a new Icom
A210, and was testing it, and adjusting my VOX squelches.
G. O'Shea
Sent: November 22, 2008 7:51 PM
Hmmm
up
at 3.3 to 3.5*'s
Elite 645E
Can't help with the tail height vs angle,Walter, as my mounting struts are
shorter than MAM spec...and my spreaders a tad narrower as well to maintain
the load angles of the struts.
Do you have any holes left on your rear strut fittings? One hole seems to =
about 0.4 degrees or so...and if you have any turnbuckle thread left
lowering doesn't change the cable lengths too much.
Sent: Saturday, November 22, 2008 11:23 PM
was
told them to try 3.
Does
load.
G. O'Shea
horse
run
he
Hmmm
only
3
up
at 3.3 to 3.5*'s
by Walter Klatt
Yes, I had purposely left holes on top and bottom. But I didn't want to have
to redo cables, which is why I was waiting for a down time opportunity.
Maybe this winter, as I want to take the floats off some time for a thorough
inspection and replacement of the hydraulic and brake lines.
I got my pads replaced, as you suggested, at the local shop on the field,
and they didn't gouge me too bad, I think, at 61 bucks incl tax for all
four. Brakes are good now.
G. O'Shea
Sent: November 22, 2008 8:32 PM
was
told them to try 3.
Does
load.
G. O'Shea
horse
run
he
Hmmm
only
3
up
at 3.3 to 3.5*'s
Pretty cheap Walter... I've had to pay as much as $16 A PAD at times just to
get stock.
I dropped Howard's1 hole and had just enough TBuckle thread left to
retighten the cables. When the new owner wanted more throat angle.. I got
rid of the "tangs" at the top attach fitting and replaced the bolt with an
eye bolt.. then used it's eye to attach the TBuckle clevis pin...giving me
full turnbuckle thread usage again without making new cables.
Sent: Sunday, November 23, 2008 9:49 AM
have
thorough
G. O'Shea
maintain
was
told them to try 3.
Does
load.
G. O'Shea
horse
run
Rebel.
he
Hmmm
by Drew Dalgleish
My floats are at 2.5 and if I rush my take off it will drag the heels
unless I lift one float out first. I've resisted increasing the angle
because I believed my cruise speed would suffer. Any idea how much the
extra drag slows you down?
Hmmm
up
at 3.3 to 3.5*'s
