[rebel-builders] RE: O-235 with Amphibs
Post by Walter Klatt » Sun Feb 19, 2012 8:02 pm
It's all about weight and density altitude. With the 320, it would get off
the water as quick as 10 seconds, if I was near sea level and solo with 1/2
fuel. But at 3000 feet, 2 people and full fuel it would struggle and run for
30 seconds or more. So with 115 hp, I don't think you would get off at that
load and altitude. But near sea level, you probably would be OK as long as
you have lots of room. Any head wind really helps too.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of David
Jackson
Sent: November 14, 2008 11:02 AM
To: Rebel Builders
Subject: [rebel-builders] RE: O-235 with Amphibs
At sea level with standard temperature and pressure and a long lake you are
probably OK. On a "hot and high" day with a small lake in the mountains,
I'm not so sure. Amphibs probably have a bit more drag in the water but
your max gross is the same with straight floats as with amphibs.
Subject: RE: [rebel-builders] 0-200 MOTOR MOUNT> Date: Fri, 14 Nov 2008
08:56:22 -0600> From: ej@cooksonhills.com> To: rebel-builders@dcsol.com> >
Does the 0-235 L2C have enough power to get a Rebel off the water on 1800
amphibs. or is that asking to much of it?> > -----Original Message----->
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Keith
Leitch> Sent: Friday, November 14, 2008 8:43 AM> To:
rebel-builders@dcsol.com> Subject: RE: [rebel-builders] 0-200 MOTOR MOUNT> >
Sorry, I don't mean to get off track on your post. If you have an O-200 I
can understand your question. But as far as the others, I personnally don't
see much sense in using the O-235/IO-240 unless you have access to one for
cheap. I have an O-235 L2C I had thought about installing in my Rebel
(whenever I get to that point) but after looking at the weight vs. the O-320
it is sensless to me. May as well use the O-320 and if you are worried about
fuel....that little thing called the throttle c
easily be pulled back.
I recently was on a 5+ hour tour with a bunch of Super Cubs and I was flying
my O-300 powered 172. Flying at their speeds I burn a little over 5 gph. I
guess what I am trying to say is it is nice to have the HP when you need
it....just don't have to use it all the time if you are concerned with fuel
prices.> I am waiting for Ron to get his Jabiru powered Rebel flying so I
can get a report. :) The power to weight ratio may be an option for me
since I will be on floats/skis the majority of the time.> Keith R661> > >
--- On Fri, 11/14/08, Jean Poirier <jean.poirier@oxyportneuf.com> wrote:> >
From: Jean Poirier <jean.poirier@oxyportneuf.com>> Subject: RE:
[rebel-builders] 0-200 MOTOR MOUNT> To: rebel-builders@dcsol.com> Date:
Friday, November 14, 2008, 8:30 AM> > Another thing...> > The IO-240 is
about the same price as the O-320... With 25-35 hp less...> The O-235 L2C
could also be "pump" to 125 hp... The Jabiru 6> cylinders also> show 120 hp>
Jean> Rebel 747R> > Jean Poirier> Pr
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 8:02 pm
Bob Patterson had one Amphib Rebel on 0-235. You should talk to him first!
Jean Poirier
Pr
Eric Johnson
Post by Eric Johnson » Sun Feb 19, 2012 8:02 pm
Thank you for the information. ej
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Walter Klatt
Sent: Friday, November 14, 2008 2:53 PM
Subject: RE: [rebel-builders] RE: O-235 with Amphibs
Jackson
To: Rebel Builders
