Yes, I do have a Cont. 0-200 that I am considering using on my Rebel. There are several reasons. I am trying to keep it light enough to qualify as LSA, 1320 lb. gross. I am using the std. bungee gear setup and have cut my fuel bays back to "two" bays per wing. I am located in the Southeastern USA and my field elevation is 500 feet above sea level. I never intend on putting the aircraft on floats. Additionally, my weight is 150 lbs. and fly alone 99% of the time. This is why I think 100 hp "might" do the job. Cris 719R
Sent: Friday, November 14, 2008 8:43 AM
To:
rebel-builders@dcsol.com
Subject: RE: [rebel-builders] 0-200 MOTOR MOUNT
Sorry, I don't mean to get off track on your post. If you have an O-200 I can understand your question. But as far as the others, I personnally don't see much sense in using the O-235/IO-240 unless you have access to one for cheap. I have an O-235 L2C I had thought about installing in my Rebel (whenever I get to that point) but after looking at the weight vs. the O-320 it is sensless to me. May as well use the O-320 and if you are worried about fuel....that little thing called the throttle can easily be pulled back. I recently was on a 5+ hour tour with a bunch of Super Cubs and I was flying my O-300 powered 172. Flying at their speeds I burn a little over 5 gph. I guess what I am trying to say is it is nice to have the HP when you need it....just don't have to use it all the time if you are concerned with fuel prices.
I am waiting for Ron to get his Jabiru powered Rebel flying so I can get a report. :)? The power to weight ratio may be an option for me since I will be on floats/skis the majority of the time.
Keith R661
--- On Fri, 11/14/08, Jean Poirier <
To:
Date: Friday, November 14, 2008, 8:30 AM
Another thing...
The IO-240 is about the same price as the O-320... With 25-35 hp less...
The O-235 L2C could also be "pump" to 125 hp... The Jabiru 6
cylinders also
show 120 hp
Jean
Rebel 747R
Jean Poirier
Pr?sident
Oxyg?ne Portneuf Inc.
-----Message d'origine-----
De?: Jean Poirier [mailto:
jean.poirier@oxyportneuf.com]
Envoy?: 14 novembre, 2008 09:26
rebel-builders@dcsol.com'
Objet?: RE: [rebel-builders] 0-200 MOTOR MOUNT
Hello
As I know, it should fit. May be the IO-240 had some mod for the
accessories... but the "mount" should be the same (as per Franklin
0-240
too).
I do not understand that Murphy tech don't know that... THEY should know
or
at least find the answer for you!
Jean
Rebel 747R
Jean Poirier
Pr?sident
De?:
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] De la part de Karen
McCaffery
Envoy?: 14 novembre, 2008 09:13
Objet?: [rebel-builders] 0-200 MOTOR MOUNT
Rebel Builders, I contacted Murphy and inquired about a motor mount for
a Continental 0-200. Murphy replied that they do now have a motor mount
for the Cont. IO-240. Would the IO-240 mount work for the 0-200? Do any
builders know the answer to this question?
Thanks, Cris 719R
Sent: Thursday, November 13, 2008 8:50 PM
To:
Subject: [rebel-builders] Spruce Panel Builder
Hi all !
This might be useful to those who are about to start on
laying out their instrument panels .....
http://www.aircraftspruce.com/panelIntro.html
You do have to register, but it should be a help !
bobp@prosumers.ca
http://www.prosumers.ca/Ramble09
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
__________ Information NOD32 3613 (20081114) __________
Ce message a ete verifie par NOD32 Antivirus System.
http://www.nod32.com
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
