[rebel-builders] stol kit glue
Post by Ken » Sun Feb 19, 2012 5:02 pm
Use it if it hasn't started to harden in the tube.
Marine suppliers usually have the stuff but I'd just use Sikkaflex 1A
from a masonry or building supplier. I get it from Patene masonry supply
in Guelph. Some tool rental companies may even have it. Seems to work
fine on floats.
mike jones wrote:
Where can I get sika flex to glue on the blocks for the stol kit that angus
sells, my tube says expired, or should I still use it since it was never
opened
Mike#007
robert
Post by robert » Sun Feb 19, 2012 5:02 pm
You can order it online from Jamestown Marina's website.
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Sent: Nov 7, 2008 12:31 PM
Subject: [rebel-builders] stol kit glue
opened
Mike#007
Sent via BlackBerry by AT&T
Post by Drew Dalgleish » Sun Feb 19, 2012 5:02 pm
opened
Mike#007
I used lots of expired sikaflex when I was building my floats. If it hasn't
gone hard it will be fine. Or google sika canada for a dealer near you.
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:02 pm
I just used a tube of 1A with a 2004 expiry date. Had to cut the nozzle off
to get past the hard stuff and then a putty knife to get some contents from
the middle. I works just fine.... ;O)
Sent: Friday, November 07, 2008 6:45 PM
Subject: Re: [rebel-builders] stol kit glue
angus
opened
Mike#007
hasn't
