[rebel-builders] fin attach
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 7:56 pm
correction;the front attach bracket doesn't reach the fus 43 bulkhead
(not fus 36)The only thing
I can see is either the horizontal bulkhead is too long or the pre
punched holes in the bulkhead
are in the wrong place.Anyone seen that before?Any problems using a
3/16' spacer to fill the gap?
Would have to do the same for the stabs.
thanks
Jason
On 15-Oct-08, at 4:21 PM, Rebecca Brownell wrote:
Hi all
Ran into a wee problem today mounting the fin.If anyone could offer
some insight it would be appreciated.
Mounted the horizontal bulkhead, stood the fin up to it and the front
attach bracket does not reach the fus 36 bulkhead
by 3/16".The fus 30 wrap stays flat on the table with the rest of the
tail cone doesn't it?
Slightly baffeled
Jason
817R
Post by Bob Patterson » Sun Feb 19, 2012 7:56 pm
Hi Jason !
DO NOT USE SPACERS !!! Have a look in the archives -
there's a very good chance the problem is with the bulkhead
positioning. There was some email about that exact problem
within the last year ....
bobp@prosumers.ca
http://www.prosumers.ca/Ramble08
thanks
Jason
Hi all
Slightly baffeled
Jason
817R
Post by Ken » Sun Feb 19, 2012 7:56 pm
Not all Fus-30's are perfectly flat on the table from what I can see on
flying Rebels. I do recall bending the stab forward attach brackets a
bit to get a good fit. Also recall adjusting the vertical fin forward a
bit I think for same reason.
Hi all
Slightly baffeled
Jason
817R
Rebecca Brownell
Thanks Ken,Bob
It is the positioning of the bulkhead.The pre punched holes in the
solid bulkhead are exactly 3/16' off of centre on the flanges, the
exact distance I am out.I think with a little finesse I can make 'er
work.I thought the holes looked a little close to the edge when I first
clecoed it on.Should have checked.Can't complain though,It's amazing
how well everything has lined up so far.
Thanks so much for the input,greatly appreciated.
Jason
817R
on
forward a
Hi all
Slightly baffeled
Jason
817R
Post by Craig Walls » Sun Feb 19, 2012 7:56 pm
Hi Jason,
So is this a manufacturing problem? If so confirming it's FUS-43? Thanks,
Craig
Rebecca Brownell
Sent: Wednesday, October 15, 2008 4:26 PM
Subject: Re: [rebel-builders] fin attach
Thanks Ken,Bob
Jason
817R
on
forward a
Hi all
Slightly baffeled
Jason
817R
Rebecca Brownell
Hi Craig
Don't think it's a problem ,just check the edge distance of the pre
punched holes in the one piece bulkhead(fus 36?)before
you drill the fus 29 wraps.doing it again I would mock up the fin and
the horizontal bulkhead(fus31)before I drilled the skins.
My manual said to drill the holes in the fus 36 but they were already
pre punched.hope this is some help.
Jason
On 16-Oct-08, at 2:13 AM, Craig Walls wrote:
Hi Jason,
Craig
Rebecca Brownell
Thanks Ken,Bob
first
Jason
817R
on
forward a
Hi all
front
Slightly baffeled
Jason
817R
bransom
Post by bransom » Sun Feb 19, 2012 7:56 pm
Jason
I ran into this too. I'm dashing to a meeting so can't recall details -- I
think the problem was that just a minor difference in the angle of the aft
most bulkhead translates to the mismatch you (and I and others) run into.
That angle is determined by a couple holes only inches apart. Try shifting
the angle of that aft bulkhead and you'll see the fix come into place.
I documented my fix at: http://mae.ucdavis.edu/ransom/Murphy/11.06/
-Ben
bransom
Correction: Detail of what I ran into is better described in
http://mae.ucdavis.edu/ransom/Murphy/10.06/
In particular starting with filename 509c and diagrammed in the last file
in that folder 'fin_fit_problem'
My post earlier this morning is wrt the fix.
-Ben
On 10/16/2008 7:56 AM, bransom wrote to rebel-builders:
Jason
-Ben
c g
Post by c g » Sun Feb 19, 2012 7:56 pm
Ben,
Are in Davis? If so, can I give you a call about your Rebel?
Chuck Goosic
Fresno,Ca
559 246 2614
Date: Thursday, October 16, 2008, 8:56 AM
Jason
-- I
-Ben
bransom
Yep. Davis.
I won't be home this evening and not too much Friday evening either, but
try me then or the wknd. (or whenever)
530-753-3960
-Ben
Ben,
Chuck Goosic
Fresno,Ca
559 246 2614
Jason
-- I
-Ben
