Craig,
As a 10+ year builder of a 95%? Elite, keep at it every day. (Should take my own advice!) Try to envision the future results of each step and do all the work in a timely fashion. Sometimes wiring or systems are more easily installed at an earlier or later point in the construction. Also, do make modifications that will allow later maintenance to be easier. An example is the suggestion to add interior nut plates for flaperon hinges. Another is to add access plates to allow later replacement or wiring inspection in otherwise difficult areas.
