Received: from MMoreho699@aol.com
by imo17.mx.aol.com (IMOv14.1) id GPWEa21163;
Tue, 5 May 1998 13:39:48 -0400 (EDT)
Message-ID: <d550cce.354f4ee5@aol.com>
Date: Tue, 5 May 1998 13:39:48 EDT
Cc: murtech@murphyair.com
Mime-Version: 1.0
Subject: 3/32" rivets for tailcone inner floor
X-Mailer: AOL 2.7 for Mac sub 3
Hello!
Just putting the finnishing touches on the inner floor. I don't plan on
riveting since I might need access later for wiring or FAA inspection.
While I was placing the rolled corners I found that the inner flange of the
bulkhead corners were much narrower than the straight parts. Except for one
odd wide flange, there is not enough room for 1/8" rivets there. I was
thinking of smaller rivets or not doing them at all.
Also I messed up during the overlap where one rolled corner ends and the
other
begins. I wanted to rivet the two pieces to these skinny bulkhead corners,
but
somehow botched aligning the holes. So I elected to extend the overlap a
little and make a second row of rivets that fastens only the rolled corners
themselves without being secured to the bulkhead. I figured this would be
okay
since it's not bearing much of a load.
Comments?
Dan
