PROSEAL
klehman
PROSEAL
Post by klehman » Fri Feb 17, 2012 8:26 pm
Ian
As long as it has been refrigerated it should be fine for a few years.
Lots of discussion on this but apparently even the manufacturer
regularly retests the stuff and puts a new date on it. If frozen the
stuff lasts for years but stir the black hardener before you measure it
out and mix up a batch.
allsure wrote:
G'day
I have a query regarding out of date PROSEAL.
I am just going to seal my wings now and have noticed that the expiry
date on the can is April 2000.
Could I expect that it will be still usable or should I junk the cans?
Regards
Ian Donaldson
PROSEAL
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:26 pm
Ian, like Ken stated, make sure you mix the hardener before use, other than that the stuff should be fine. I gave an old 1/2 used can dated 1993 to an AME this summer to do a patch job on his floats. The stuff worked fine and most likely would have been fine in a fuel tank. I have numerous cans from current to 6 years old (stored in a fridge, not frozen) and just set them out in the sunshine for an hour or so, to let them warm up prior to mixing. Haven't had ANY vintages let me down yet!
Blue skies,
Sent: Tuesday, September 19, 2000 8:39 AM
Subject: PROSEAL
G'day
I am just going to seal my wings now and have noticed that the expiry date on the can is April 2000.
Regards
Ian Donaldson
PROSEAL
Post by Bob Patterson » Fri Feb 17, 2012 8:26 pm
Most likely it is still good - especially if you have stored it
in a freezer ....
If in doubt, stir up the hardener, then mix a small test batch.
Folks have used ProSeal that was years out of date, with acceptable
results ...
------------------------------orig.----------------------------------------
At 08:39 PM 9/19/00 +0800, you wrote:
G'day
Regards
Ian Donaldson
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2919.6307" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT size=2>G'day</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>I have a query regarding out of date PROSEAL.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>I am just going to seal my wings now and have noticed
that the
expiry date on the can is April 2000.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>Could I expect&nbsp;that&nbsp;it will be still usable or
should&nbsp;I junk the cans?</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>Regards</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>Ian Donaldson</FONT></DIV></BODY></HTML>
allsure
PROSEAL
Post by allsure » Fri Feb 17, 2012 8:26 pm
G'day
Regards
Ian Donaldson
Lonnie Benson
PROSEAL
Post by Lonnie Benson » Fri Feb 17, 2012 8:26 pm
Ian,
Your pro-seal should be thick and hard to stir. You can buy pro-seal in
tubes and in different viscosities. I purchased some that was "brushable"
i.e. I could apply it with a paint brush. I troweled (actually used wooden
tongue depressors) the thick stuff on and then when it was dry went back
over it with the thinner mix. I have heard of people thinning the thick mix
with toluene. Have you checked the archives for pro-seal hints etc.?
Lonnie Benson
Rebel #171
Sent: Thursday, September 21, 2000 11:18 AM
Subject: Re: PROSEAL
G'day
My PROSEAL has sat on the shelf unrefrigerated for more than 10 months!
What should the consistency be like? The PROSEAL is quite thick and rather
difficult to stir
Can it be thinned to allow easier working or do it just trowel it on ?
I have seen that some use syringes to apply it, but I think what I have is
too thick to easily be put into a syringe.
Any suggestions?
Regards
Ian Donaldson
Drew and Jan
PROSEAL
Post by Drew and Jan » Fri Feb 17, 2012 8:26 pm
Ian I have some pro seal made in june this year for my floats. its not as
thick as peanut butter before mixing but it stiffens up quite a bit as soon
as its mixed. The temperature that you're using it at makes a lot of
difference as well. To get it really runny I've popped it in the microwave
for a few seconds you have to work fast though as this drastically reduces
the pot life. To use a syringe cut the end off and make the hole as big as
you need. Hope this helps Drew.
At 10:20 AM 9/21/00 -0400, you wrote:
Ian,
Lonnie Benson
Rebel #171
G'day
difficult to stir
Any suggestions?
Regards
Ian Donaldson
Click here for Free Video!!
http://www.gohip.com/freevideo/
allsure
PROSEAL
G'day
difficult to stir
Any suggestions?
Regards
Ian Donaldson
PROSEAL
Ian,
Just a reminder - to spare yourself much grief, be sure to
mix a test batch to test curing & adhesion, BEFORE doing the 'real thing' !
Also, apparently it is the black HARDENER that settles in the
can, and needs stirring BEFORE measuring out & mixing....
Good Luck !!
....bobp
At 09:42 PM 9/23/00 +0800, you wrote:
Thanks Drew
I have found that the can of proseal had formed a thick crust where some of
the product had hardened.
I just removed the crust and the rest of the contents are as you described.
All I have to do now is figure how to get it in a syringe. I have that
feeling that I will get more on me than in the
syringe!
Thanks and regards
Ian Donaldson
Sent: Friday, September 22, 2000 8:46 PM
soon
Ian,
"brushable"
wooden
mix
Lonnie Benson
Rebel #171
rather
is
allsure
PROSEAL
Thanks Drew
syringe!
Thanks and regards
Ian Donaldson
soon
Ian,
"brushable"
wooden
mix
Lonnie Benson
Rebel #171
G'day
rather
difficult to stir
is
Any suggestions?
Regards
Ian Donaldson
PROSEAL
Your following message has been delivered to the 167 members of
the list murphy-rebel@dcsol.com at 10:25:13 on 24 Sep 2000.
Ian, do yourself a favour and buy a box of a 100 latex gloves. If you put 2
pairs on at a time, when the top layer gets too messy you can strip to the
clean ones and then put on a new pair over top! I did my first wings without
gloves and got tired of hidding my hands in my pockets for weeks afterwards
when out in public. Also the curing agents being absorbed though your skin
and lungs are not too great for your liver either! The gloves will take care
of one, LOTS of ventilation (or a fresh air hood system as I now use) will
take care of the other.
Have fun,
Sent: Sunday, September 24, 2000 11:24 AM
G'day
I mixed a test batch and it all seems fine and the proseal has cured OK
However the proseal sure gets into the pores of your skin! My hands
definitely won't leak!
Regards
Ian Donaldson
Sent: Sunday, September 24, 2000 9:31 AM
Ian,
thing'
Drew and Jan
PROSEAL
Ian get a box of latex gloves and change to new ones every time they get
sticky or you'll be cleaning Pro Seal off your plane and tools forever Drew
At 11:24 PM 9/24/00 +0800, you wrote:
G'day
Regards
Ian Donaldson
Ian,
allsure
PROSEAL
G'day
Regards
Ian Donaldson
Ian,
allsure
PROSEAL
G'day
Thanks to everyone for their response regarding proseal.
I have purchased a pack of latex gloves which sure helps in keeping my hands
clean, but the whole process is still messy none the less.
I have taken Waynes tip regarding fresh air and now keep the garage doors
wide open.
Regards
Ian Donaldson
Sent: Sunday, September 24, 2000 10:23 PM
2
without
afterwards
skin
care
Have fun,
G'day
Regards
Ian Donaldson
Ian,
thing'
Charles Skorupa
Proseal
Post by Charles Skorupa » Fri Feb 17, 2012 8:26 pm
SEALPAK was the tank sealant that Murphy provided with my kit. This stuff
could hold the San Andreus fault together.
- Chuck Skorupa -
Elite SN 500
Sent: Wednesday, October 04, 2000 3:10 PM
Subject: Re: Proseal
Ian,
Don't know of any alternative hardeners, and <I> would be VERY
unwilling to experiment !! It is MUCH easier to do it RIGHT, now,
than try to take it apart later to fix it !!!! (right, Wayne ??)
The only other material that meets the same MIL spec is
called SEALPAK, but again - why mix 'n match ??? You can order
ProSeal from Murphy, if all else fails (their distributor in OZ might
have some on hand ...)
-------------------------------orig.--------------------------------------
At 01:12 AM 10/5/00 +0800, you wrote:
G'day
The saga with proseal continues! Somehow I have managed to spill most of
the accelerator. Unfortunately here in Australia we cannot readily get
Proseal and I was wondering if anyone knew whether I could use something
other than the factory supplied accelerator, and if so just what that
would be.
It also appears that I might not have enough Proseal to finish the tanks.
Has anyone any experience with other sealants that may be satisfactory and
be compatible with Proseal.
Thanks and regards
Ian Donaldson
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>The saga with proseal continues! Somehow I have managed
spill most of the accelerator. Unfortunately here in Australia we cannot
readily
get&nbsp;Proseal and I was wondering if anyone knew whether I could use
something other than the factory supplied accelerator, and if so just
what
that
would be. </FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>It also appears that I might not have enough Proseal to
finish
the tanks. Has anyone any experience with other sealants that may be
satisfactory and be compatible with Proseal.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>Thanks and regards</FONT></DIV>
<DIV>&nbsp;</DIV>
Proseal
Ian,
-------------------------------orig.---------------------------------------
G'day
other than the factory supplied accelerator, and if so just what that would be.
Thanks and regards
Ian Donaldson
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>The saga with proseal continues! Somehow I have managed to
readily
something other than the factory supplied accelerator, and if so just what
that
<DIV>&nbsp;</DIV>
finish
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
