Murphy uses a standard Watts check valve series #6 (my recollection). Check
the web and the Watts website for details:
http://www.watts.com/pro/_productsFull. ... =625&ref=1
Max pressure is on the order of 200 psi. This is a generic low tech check
valve.
I also couldn't get my valves from Murphy 6 months ago, so I went to local
plumbing supply and got an equivalent check valve from another company
(sorry, don't have the name right now).
If you go to your local plumbing supply that carries regulators, valves,
etc., for compressed gases and liquids, they will be able to get you Watts
check valve or an equivalent.
I got an equivalent which may be slightly larger than the Watts and so
cannot locate the check valves side by side as Murphy diagrams.
Eric Fogelin
Elite #645
Almost ready to start engine
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Clay
Smith
Sent: Tuesday, July 22, 2008 6:20 AM
Subject: [rebel-builders] Hand Pump check-valves
MAM is having a problems locating the check-valves for my Amphib hand pump.
Backered for 2 months now. Anyone know of a source?
Clay
Clay Smith
Hey Eric, thanks so much for the info! I'll have to do some more checking
around - I was looking in hydraulic supply stores with no luck.
Clay
Sent: Wednesday, July 23, 2008 1:14 AM
Subject: RE: [rebel-builders] Hand Pump check-valves
Clay
Check
valve.
Eric Fogelin
Elite #645
Smith
pump.
Clay
kitplane_solutions
Hi Clay
Take a look at this sight these would work. It would be best to find ones with
the lowest cracking pressure possible as it will.
http://www.hydraulicstore.com/checkvalves.html
Sean
On 7/23/2008 2:06 PM, cbsmith@nf.sympatico.ca wrote to rebel-builders:
-> Hey Eric, thanks so much for the info! I'll have to do some more
checking
-> around - I was looking in hydraulic supply stores with no luck.
-> Clay
-> From: "Eric Fogelin" <elist@whidbey.com>
-> Sent: Wednesday, July 23, 2008 1:14 AM
-> Subject: RE: [rebel-builders] Hand Pump check-valves
-> > Murphy uses a standard Watts check valve series #6 (my recollection).
-> > Check
-> > the web and the Watts website for details:
-> > http://www.watts.com/pro/_productsFull. ... =625&ref=1
-> > Max pressure is on the order of 200 psi. This is a generic low tech check
-> > valve.
-> > I also couldn't get my valves from Murphy 6 months ago, so I went to
local
-> > plumbing supply and got an equivalent check valve from another
company
-> > (sorry, don't have the name right now).
-> > If you go to your local plumbing supply that carries regulators, valves,
-> > etc., for compressed gases and liquids, they will be able to get you
Watts
-> > check valve or an equivalent.
-> > I got an equivalent which may be slightly larger than the Watts and so
-> > cannot locate the check valves side by side as Murphy diagrams.
-> > Eric Fogelin
-> > Elite #645
-> > Almost ready to start engine
-> > -----Original Message-----
-> > From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On
Behalf Of Clay
-> > Smith
-> > Sent: Tuesday, July 22, 2008 6:20 AM
-> > To: rebel-builders@dcsol.com
-> > Subject: [rebel-builders] Hand Pump check-valves
-> > MAM is having a problems locating the check-valves for my Amphib
hand
-> > pump.
-> > Backered for 2 months now. Anyone know of a source?
-> > Thanks
-> > Clay
Sean
checking
-> Clay
-> > Check
-> > valve.
local
company
Watts
-> > Eric Fogelin
-> > Elite #645
Behalf Of Clay
-> > Smith
hand
-> > pump.
-> > Thanks
-> > Clay
It's been awhile since I looked but MAM's looked homemade to me. Brass
push on hose fittings with a ball bearing and spring.
I think a pressure relief valve should be in the circuit as well and was
planning a pneumatic relief valve or regulator set at around 150 psi.
Hi Clay
Sean
checking
-> Clay
Clay Smith
Ken, I think that answers another question I had regarding the maximum psi
reached when pumping ...150 psi ? The gauge MAM sent me is 0 - 500 psi but
I was thinking of installing a 0 - 200.
I spoke with Nancy today and she's hoping to have the check-valves in soon
... 1 to 2 weeks. Hope so.
Clay
Sent: Thursday, July 24, 2008 8:57 AM
Subject: Re: [rebel-builders] Hand Pump check-valves
Clay
kitplane_solutions@dcsol.com wrote:Hi Clay
with
Sean
checking
-> Clay
At 10:50 AM 7/22/2008 -0230, you wrote:
than the murphy ones and probably cheaper as well. Neither one of my murphy
valves would hold pressure right out of the box and the factory wouldn't
give me any warranty on the first ones or on replacements if I ordered from
them.
pump. Backered for 2 months now. Anyone know of a source?MAM is having a problems locating the check-valves for my Amphib hand
I got some from the local hydraulic supply company. Much better qualityThanks
Clay
them.
