To cut three or not to cut three
Posted: Fri Feb 17, 2012 7:21 pm
by Mike Davis
Received: from tim - 208.250.191.245 by email.msn.com with Microsoft
SMTPSVC;
Mon, 4 May 1998 17:34:28 -0700
Received: by localhost with Microsoft MAPI; Mon, 4 May 1998 17:30:48 -0700
Message-ID: <01BD7782.6090D440.tlcarter@email.msn.com>
Reply-To: "tlcarter@msn.com" <tlcarter@msn.com>
To: 'Rebel Builders' <murphy-rebel@dcsol.com>
Subject: To cut three or not to cut three
Date: Mon, 4 May 1998 17:30:14 -0700
X-Mailer: Microsoft Internet E-mail/MAPI - 8.0.0.4211
MIME-Version: 1.0
Return-Path: tlcarter@email.msn.com
Hi gang:
Who has not cut their firewall back and is using a Lyc. O-320?
I don't want to cut mine back, but I wonder if there are any CG penalties,
etc...
Tim
#438R
by Mike Davis
Received: from ts57-08.tor.istar.ca [204.191.147.231]
by mail1.toronto.istar.net with smtp (Exim 1.80 #5)
id 0yWuoG-0002I9-00; Tue, 5 May 1998 23:23:57 -0400
Mime-Version: 1.0
Subject: Re: To cut three or not to cut three
Message-Id: <E0yWuoG-0002I9-00@mail1.toronto.istar.net>
Date: Tue, 5 May 1998 23:23:57 -0400
Tim, are you planning on floats or skis ?? If so, cutting the fuse and
moving the firewall back is probably a good idea.
There ARE several Rebels flying with the F/W in the standard position
with O-320's, (and Subaru Legacy's !) and no major CG problem, BUT - the
airplane will fly better with a more aft CG position.
(competition gliders go to extremes to get aft CG, for better performance
at speed)
Floats, and especially skis, will give the aircraft a good pounding,
and having all that engine weight waaay out front gives it a long arm to
cause distortion in the F/W, side panels, etc., when smacked, so shortening
the front fuse is a good idea.
(There have been reports of hard impacts causing the top engine mounts
to move inward, distorting F/W & side panels. One fix is to add a 1" (or so)
square tube to the top inside of the F/W, connecting the 2 top engine
mounts.
This stops compression, and can carry an additional couple of tubes back
to support (triangulate) the instrument panel better.)
I agree that it changes the looks, and makes it harder to install
radios, but ...
FWIW, I know of at least ONE Rebel that had the F/W moved back a couple
of inches for an O-235-L2C, to improve handling and trim. (But it DID
have the battery on the firewall ...)
Don't forget to move the rudder pedals back a little extra, to give a
little more clearance for full rudder/full brake taxiing...
Also, since the seat is farther back, the skylights might need a little
extra thought...
----------------------------------orig.---------------------------------
At 05:30 PM 5/4/98 -0700, you wrote:
Hi gang:
etc...
Tim
#438R
