[rebel-builders] Rebel tailsprings - was Empty weight
Post by Bob Patterson » Sun Feb 19, 2012 4:43 pm
Changed the header - again !
Yes, it shouldn't be too hard to build fiberglass tailsprings - you
could lay up double or triple width & saw them apart ...
We're not Rambling yet, Tim - we leave July 12th, for a one week
trip to Quebec City & Canada'a east coast, if the weather's good ...
http://prosumers.ca/Ramble08
Everyone's welcome - still time to join in !!
Anna & I will be at Oshkosh, and hope to get together with
everybody, as usual ! :-) Maybe we'll try one more time
for a get-together at the Beer Tent ....
bobp@prosumers.ca
http://www.prosumers.ca
On Tuesday 24 June 2008 02:35, Tim Hickey wrote:
Anybody ever try to lay up a fiberglass spring?
Shouldn't be all that hard. We just need to find an ol VariEze builder and
turn him loose.
By the way, I will be putting together a master list of those planning to
attend OSH 08 in the next several days. Last year we had a very good
discussion with Mr. Murphy for an hour or so. I hope that we can do so
again.
Bob P. Can you help set this up? ( I think Bob is Rambling, but he will
get this sooner or later.)
Tim Hickey
R808
Sent: Monday, June 23, 2008 7:35 PM
Subject: Re: [rebel-builders] Empty weight
Hi Jesse !
Silver sunblocker sounds like a good idea. Never had one
fade or crumble, but have had one de-laminate over time....
the paint should protect it.
I did make a fabric cover for my wood prop - good idea
for composites, as well !
bobp@prosumers.ca
On Thursday 26 June 2008 00:57, Jesse Jenks wrote:
I have been wanting to ask this question for a while. Seems like a good
time: Is it a good idea to paint the fiberglass tailspring with some kind
of UV proof paint? The resin will probably break down in direct sunlight.
I was thinking a coat of epoxy, then a couple coats of the Polyfiber
silver.> From: bobp@prosumers.ca> To: rebel-builders@dcsol.com> Subject:
Re: [rebel-builders] Rebel tailsprings - was Empty weight> Date: Tue, 24
Jun 2008 03:10:08 +0000> > > Changed the header - again !> > Yes, it
shouldn't be too hard to build fiberglass tailsprings - you> could lay up
double or triple width & saw them apart ...> > We're not Rambling yet, Tim
- we leave July 12th, for a one week> trip to Quebec City & Canada'a east
coast, if the weather's good ...> http://prosumers.ca/Ramble08> >
Everyone's welcome - still time to join in !!> > Anna & I will be at
Oshkosh, and hope to get together with> everybody, as usual ! :-) Maybe
we'll try one more time> for a get-together at the Beer! T
ent ....> > -- > ......bobp> bob
p
@prosumers.ca> http://www.prosumers.ca>
http://bpatterson.qhealthbeauty.com> http://apatterson2.qhealthzone.com>
http://apatterson2.ordermygift.com> >
-------------------------------orig.------------------------- > On Tuesday
24 June 2008 02:35, Tim Hickey wrote:> > Anybody ever try to lay up a
fiberglass spring?> >> > Shouldn't be all that hard. We just need to find
an ol VariEze builder and> > turn him loose.> >> > By the way, I will be
putting together a master list of those planning to> > attend OSH 08 in
the next several days. Last year we had a very good> > discussion with Mr.
Murphy for an hour or so. I hope that we can do so> > again.> > Bob P. Can
you help set this up? ( I think Bob is Rambling, but he will> > get this
sooner or later.)> >> > Tim Hickey> > R808> >> >> > ----- Original Message
-----> > From: "Drew Dalgleish" <drewjan@cabletv.on.ca>> > To:
<rebel-builders@dcsol.com>> > Sent: Monday, June 23, 2008 7:35 PM> >
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 4:43 pm
Cool, Thanks Bob.> From: bobp@prosumers.ca> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] Rebel tailsprings - was Empty weight> Date: Thu, 26 Jun 2008 01:17:04 +0000> > > Hi Jesse !> > Silver sunblocker sounds like a good idea. Never had one> fade or crumble, but have had one de-laminate over time....> the paint should protect it.> > I did make a fabric cover for my wood prop - good idea> for composites, as well !> > -- > ......bobp> bobp@prosumers.ca> http://www.prosumers.ca> http://bpatterson.qhealthbeauty.com> http://apatterson2.qhealthzone.com> http://apatterson2.ordermygift.com> > -------------------------------orig.------------------------- > On Thursday 26 June 2008 00:57, Jesse Jenks wrote:> > I have been wanting to ask this question for a while. Seems like a good> > time: Is it a good idea to paint the fiberglass tailspring with some kind> > of UV proof paint? The resin will probably break down in direct sunlight.> > I was thinking a coat of epoxy, then a couple
coats of the Polyfiber>
silver.> From: bobp@prosumers.ca> To: rebel-builders@dcsol.com> Subject:> > Re: [rebel-builders] Rebel tailsprings - was Empty weight> Date: Tue, 24> > Jun 2008 03:10:08 +0000> > > Changed the header - again !> > Yes, it> > shouldn't be too hard to build fiberglass tailsprings - you> could lay up> > double or triple width & saw them apart ...> > We're not Rambling yet, Tim> > - we leave July 12th, for a one week> trip to Quebec City & Canada'a east> > coast, if the weather's good ...> http://prosumers.ca/Ramble08> >> > Everyone's welcome - still time to join in !!> > Anna & I will be at> > Oshkosh, and hope to get together with> everybody, as usual ! :-) Maybe> > we'll try one more time> for a get-together at the Beer! T> > ent ....> > -- > ......bobp> bob> > p> > @prosumers.ca> http://www.prosumers.ca>> > http://bpatterson.qhealthbeauty.com> http://apatterson2.qhealthzone.com>> > http://apatterson2.ordermygift.com> >> > -------------------------------orig.------------------------- >
On Tuesday> > 24 June
2
008 02:35, Tim Hickey wrote:> > Anybody ever try to lay up a> > fiberglass spring?> >> > Shouldn't be all that hard. We just need to find> > an ol VariEze builder and> > turn him loose.> >> > By the way, I will be> > putting together a master list of those planning to> > attend OSH 08 in> > the next several days. Last year we had a very good> > discussion with Mr.> > Murphy for an hour or so. I hope that we can do so> > again.> > Bob P. Can> > you help set this up? ( I think Bob is Rambling, but he will> > get this> > sooner or later.)> >> > Tim Hickey> > R808> >> >> > ----- Original Message> > -----> > From: "Drew Dalgleish" <drewjan@cabletv.on.ca>> > To:> > <rebel-builders@dcsol.com>> > Sent: Monday, June 23, 2008 7:35 PM> >> > > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com>
The other season of giving begins 6/24/08. Check out the i
Jesse Jenks
I have been wanting to ask this question for a while. Seems like a good time: Is it a good idea to paint the fiberglass tailspring with some kind of UV proof paint? The resin will probably break down in direct sunlight. I was thinking a coat of epoxy, then a couple coats of the Polyfiber silver.> From: bobp@prosumers.ca> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] Rebel tailsprings - was Empty weight> Date: Tue, 24 Jun 2008 03:10:08 +0000> > > Changed the header - again !> > Yes, it shouldn't be too hard to build fiberglass tailsprings - you> could lay up double or triple width & saw them apart ...> > We're not Rambling yet, Tim - we leave July 12th, for a one week> trip to Quebec City & Canada'a east coast, if the weather's good ...> http://prosumers.ca/Ramble08> > Everyone's welcome - still time to join in !!> > Anna & I will be at Oshkosh, and hope to get together with> everybody, as usual ! :-) Maybe we'll try one more time> for a get-together at the Beer Tent ....>
p
@prosumers.ca> http://www.prosumers.ca> http://bpatterson.qhealthbeauty.com> http://apatterson2.qhealthzone.com> http://apatterson2.ordermygift.com> > -------------------------------orig.------------------------- > On Tuesday 24 June 2008 02:35, Tim Hickey wrote:> > Anybody ever try to lay up a fiberglass spring?> >> > Shouldn't be all that hard. We just need to find an ol VariEze builder and> > turn him loose.> >> > By the way, I will be putting together a master list of those planning to> > attend OSH 08 in the next several days. Last year we had a very good> > discussion with Mr. Murphy for an hour or so. I hope that we can do so> > again.> > Bob P. Can you help set this up? ( I think Bob is Rambling, but he will> > get this sooner or later.)> >> > Tim Hickey> > R808> >> >> > ----- Original Message -----> > From: "Drew Dalgleish" <drewjan@cabletv.on.ca>> > To: <rebel-builders@dcsol.com>> > Sent: Monday, June 23, 2008 7:35 PM> > Subject: Re: [rebel-builders] Empty weight> >> > > > >
-------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
