I just took a look a look at my notes and photographs. I did drill #30 and
rivet the door sills but not in either the front or rear positions where you
will eventually rivet the door sills to the square tube cage and at the rear
to the vertical skins that attach the cabin to the tail. As I recall, these
still require some extra measuring and squaring before final drill and
rivet. Leave those #40 until you have to tops of the door and roof skin in
place. Even then, you have some other skins that go forward to the firewall
that still need to be fitted.
Eric Fogelin
Elite 645
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Roger
Cole
Sent: Thursday, June 05, 2008 6:40 PM
To: Rebel Builders
Subject: [rebel-builders] Door sill install question
I have completed the instructions titled "Door Sill Install" which
says to drill the holes to #40 and cleco together. I couldn't find
an instruction to drill out to #30, deburr, chromate, and rivet. Is
there a later step that requires that the holes be left at #40, or
should I drill out to #30 and rivet now?
Thanks in advance for your helpful advice.
Roger Cole
Murphy Elite #709
rcole927@earthlink.net
Eric,
Thanks! That is exactly the information that I need.
---------------Roger
#30 and
where you
the rear
recall, these
skin in
firewall
Eric Fogelin
Elite 645
Of Roger
Cole
To: Rebel Builders
Roger Cole
Murphy Elite #709
