[rebel-builders] Oil pressure gauge
Post by Ken » Sun Feb 19, 2012 4:43 pm
It it helps, I have a 0-30 psi VDO electric sensor that feeds my Grand
Rapids EIS with coolant pressure. I can find a part number if you need
it. There must be an analog gauge that goes with that.
On occasion I've also fed ordinary voltmeters with such sensors but
these days I'd look for a solid state sensor if making a custom sensor.
Mike Kimball wrote:
Does anybody know where I can get an electric, 0-30 psi oil pressure gauge?
My PSRU runs between 0 and 20 psi depending on RPM and I can't monitor that
very well with the 0-80 psi gauge I currently have.
044SR
Post by Mike Davis » Sun Feb 19, 2012 4:43 pm
The second gauge on the page can be set for 0-30... it says fuel pressure on
the gauge, but the sending unit for it says oil/fuel/air, so don't know why
it wouldn't work.
http://www.tbyrnemotorsports.com/Cadill ... auges.html
To: "Rebel Builder's List" <rebel-builders@dcsol.com>
Sent: Friday, May 23, 2008 8:53 PM
Subject: [rebel-builders] Oil pressure gauge
gauge?
that
044SR
