[rebel-builders] VOR antenna orientation
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 4:42 pm
No technical advantage from a radiation point of view Ted. Usually
easier on the mounting points to have the elements trailing but no big
deal either way.
Garry
068R
Ted Waltman wrote:
Putting my VOR antenna's in the tail fin this weekend. I seem to recall
"always" seeing them pointed with the "V" toward the rear. Yet, here's a
picture with them pointed forward (www.metalcrafters.ph/pics/wip/wip%205.jpg
). Does anyone know of a reason / advantage to point them one way or the
other?
Thank you,
Steve Halvorsen
Post by Steve Halvorsen » Sun Feb 19, 2012 4:42 pm
Ted,
The only reason they go forward is if you can't get clearence for the rudder to get its full deflection.
On our Moose they go to the rear.
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 4:42 pm
I mounted my Comant VOR antenna forward on the tail fin in the area where
the fiberglass tip is located. I did this for two reasons:
1) The Comant installation instructions recommend this direction
2) It was the only direction that worked due to the wide rudder and fin
There are other antennas that start out perpendicular to the fin and then
angle out. These might work with the wide Murphy rudder. Many like pointing
backwards for aesthetics. I've also heard that iced up forward mounted
antennas tend to snap off. Staying out of ice would solve this issue. Comant
says that rear mounting is okay, but better signal is received mounting
forward.
Eric Fogelin
Elite 645E
Waltman
Sent: Thursday, May 15, 2008 4:37 PM
Subject: [rebel-builders] VOR antenna orientation
other?
Thank you,
