another new rebel is born
Post by Drew Dalgleish » Sun Feb 19, 2012 4:42 pm
Mike Ash must be feeling shy so I'll report that on april 24 I had the
honour of watching C-FBNO on it's first flight. All went as planned with
good cooling and hands off rigging. Afterwards one small oil leak was found
and repaired and the prop might be too fine but Mike And Kathy are one very
happy couple. There's a picture in the completed section.
indabush
Post by indabush » Sun Feb 19, 2012 4:42 pm
Thanks Drew,
Yes, I was thinking that I should get the news out before this. You know
what thought did. To me, it won't really be done until the 25 hours are
signed off. With weather and schedules, the hours are not going as fast as
I would like, but progress is being made. As Drew mentioned, the Prince 74
X 47 prop may be too fine, but it sure does climb! I also believe the ASI
is reading too high, but haven't had a calm enough day to calibrate it
accurately. I got static ports that are not flush mounted and I think that
is the problem.
I have not been a big contributor over the years, but I have learn a lot
by reading the digest. Thanks everyone, for contributing to a successful
lift-off. I am definitely smiling.
Sincerely, Mike. :-)
_______________________________________
Date: Tue, 13 May 2008 22:17:49 -0400
To: rebel-builders
Subject: another new rebel is born
found
very
indabush
Thanks Bob,
I had the tach checked and it is reading accurately. With the climb rate,
it's almost like being a helicopter again.
I could easily disconnect the static lines in the cabin. I forget, does
cabin pressure tend to be higher or lower than ambient? Definitely no IFR.
Mike / C-FNBO
