Of course I meant "then slip the horizontal stab in" after the elevator is
through the slot hanging loose (hopefully held by your two friends). I
think I remember it was easiest when the elevator was drooped down with the
leading edge sticking up, in fact, held up against the top of the slot. On
the side of the airplane that you are standing, holding the elevator to put
through the slot, the elevator has to be angled down a bit to get the stab
past it. You might think about putting some duct tape or something all
around the slot to help protect your paint when (not if) you accidentally
bang the elevator or stab on the edges of the slot.
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of Mike
Kimball
Sent: Friday, May 09, 2008 7:05 PM
To:
rebel-builders@dcsol.com
Subject: RE: [rebel-builders] Moose: putting on controls / wings
I've done the horizontal stab and elevator a few times by myself but I would
highly recommend two people. Three would be even better since you will want
to be extra careful with the new paint job. Elevator goes through the slot
first, pushed as far back as it will go. Then slip the elevator in. You
have to hold your tongue just right, wiggling and adjusting.
If the access holes to get to the bolts holding the elevator to the
horizontal stab are still cut the way mine were from MAM you will want to
make them bigger. You'll never get the bolts in place through the original
access.
mike.davis@dcsol.com] On Behalf Of Ted
Waltman
Sent: Friday, May 09, 2008 11:27 AM
To:
Subject: [rebel-builders] Moose: putting on controls / wings
Going to be putting on rudder, h-stab and elevator this weekend. Plan to
put wings on and other controls sometime next week. Does anyone have any
tricks/advice/suggestions besides what the manual offers?
Thank you,
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
