[rebel-builders] Correct dimension needed
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 4:38 pm
Roger,
The ST-31 channel should have an outside measurement of 2", the FUS-411
measures about 3 3/16" from bottom to centre of pulley bolt hole --
therefore leaving your 1 3/16" distance, your pulley bolt location will be
1/16 higher than set out in FIG 9.4.4 -- not a crucial distance.
Or you can set the FUS-411 so the pulley bolt location is 1 1/18 like in the
manual and trim bottom to suit for clearance, you will still have plenty of
rivet edge distance - min ED being 1.5 x diameter of hole.
Jeff
On Thu, May 8, 2008 at 2:51 PM, Roger Cole <rcole927@earthlink.net> wrote:
Figure 9.4.4 of the Elite tail cone assembly calls for drilling 9
holes that would locate the lower elevator pulley bolt 1 1/8-in above
the ST-31 channel. That dimension can't be correct because it would
position the bottom of the FUS-411 pulley bracket below the ST-31
channel where it would interfere with the bottom skin. What is the
correct dimension?
Roger Cole
Murphy Elite #709
