[rebel-builders] Rebel - New engine is flying
Post by Bob Patterson » Sun Feb 19, 2012 4:38 pm
Congrats, Walter !
Your prop might not be tooooo fine - Pierre's 360
would go past 2,900 rpm if I didn't climb at 65 mph -
and that gave 2,300 FPM !!!!
THAT prop WAS too fine !! :-)
Think it was a 74 x 44 Prince ... A later 74 x 48 was
a bit too coarse ...
bobp@prosumers.ca
http://www.prosumers.ca
On Monday 05 May 2008 00:01, Walter Klatt wrote:
Finally got my new O-360 engine flying in the Rebel today. Definitely way
more power, no question about that. Am trying to break in the new
cylinders and having trouble getting up to 22 MAP or 65% power without
going too fast. My windows start opening up a bit at the front at 125 mph.
My prop might be too fine, as I have to run about 2500 rpm to get 22 MAP.
Take off and climb is good though. Was seeing 1800 fpm on initial climb.
Basically, it now performs the same on the ampibs as it used to on wheels
with the O-320.
Really puts through the fuel though, with full power, at 18.5 gph. The
O-320 only did 13 WOT.
Handling and c of g exactly same as before. Did not have to change my
elevator trim. Did notice having to use more right rudder on take-off and
climb though.
Cooling is good, too, so very happy about that. Rear cylinders ran about
350 or less, Had to tape off the top of the oil cooler to get the oil
temps up to 185 which is the highest I saw today. OAT at the lake today
was 19 C.
Got a few adjustments to make and some finishing on the cowl, but at least
it is flying again. So I am a happy camper today.
