[rebel-builders] New engine is flying
Ron Shannon
Congrats, Walter. 1800 FPM on amphibs sounds super!
Ron
Ron
Well, I am jealous. Our time will come. Congrats craig
Klatt
Sent: Sunday, May 04, 2008 4:02 PM
To: Rebel-Builders
Subject: [rebel-builders] New engine is flying
Finally got my new O-360 engine flying in the Rebel today. Definitely way
more power, no question about that. Am trying to break in the new cylinders
and having trouble getting up to 22 MAP or 65% power without going too fast.
My windows start opening up a bit at the front at 125 mph. My prop might be
too fine, as I have to run about 2500 rpm to get 22 MAP.
Take off and climb is good though. Was seeing 1800 fpm on initial climb.
Basically, it now performs the same on the ampibs as it used to on wheels
with the O-320.
Really puts through the fuel though, with full power, at 18.5 gph. The O-320
only did 13 WOT.
Handling and c of g exactly same as before. Did not have to change my
elevator trim. Did notice having to use more right rudder on take-off and
climb though.
Cooling is good, too, so very happy about that. Rear cylinders ran about 350
or less, Had to tape off the top of the oil cooler to get the oil temps up
to 185 which is the highest I saw today. OAT at the lake today was 19 C.
Got a few adjustments to make and some finishing on the cowl, but at least
it is flying again. So I am a happy camper today.
Klatt
To: Rebel-Builders
with the O-320.
only did 13 WOT.
climb though.
jean.poirier
Happy for you!
Jean
Rebel 747R
On Sun 05/ 4/08 17:01 , Walter Klatt Walter.Klatt@shaw.ca sent:
Jean
Rebel 747R
fast.
with the O-320.
O-320
only did 13 WOT.
climb though.
350
is@dcsol.com
Garry
Congrats Walter. Nice to be back in the air - especially with all those
horseys. Looking forward to more reports on what this does for you in
the higher lakes.
Garry
the higher lakes.
Garry
with the O-320.
only did 13 WOT.
climb though.
Nigel Smith
Great news Walter... enjoy.
Just finished the second wing here. Still plodding away :-)
Nig
745E
Klatt
Sent: 05 May 2008 01:02
To: Rebel-Builders
with the O-320.
only did 13 WOT.
climb though.
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.8/1415 - Release Date: 05/05/2008
06:01
Nig
745E
Klatt
To: Rebel-Builders
with the O-320.
only did 13 WOT.
climb though.
Checked by AVG.
06:01
Good stuff Walter sounds like you're seeing about the same difference in
performance as I did going from the 0-290 to the 0-320. Lotsa fun EH.
robert
point the nose up and climb (hahaha)
Sent via BlackBerry by AT&T
Date: Sun, 04 May 2008 17:01:33
To:Rebel-Builders <rebel-builders@dcsol.com>
with the O-320.
only did 13 WOT.
climb though.
with the O-320.
only did 13 WOT.
climb though.
Garry
Congratulations Walter - looking forward to interesting reports from the
far off high places after this.
Garry
Garry
with the O-320.
only did 13 WOT.
climb though.
As I am breaking in my new engine, I am running it at full rich mixture, and
it is really putting through the fuel as I am trying to use enough power to
properly seat the rings. I have the extra rich 10-4164-1 version of the
O-360 carb so it is wasting about 3 gph in cruise by not leaning.
With fuel prices the way they are, I would like to start leaning a bit soon.
How many hours before I can lean normally? I have the ECI nickel carbide
cylinders (new high flow tapered fin exp cylinders) which are supposed to
break in very quickly.
Also, I mentioned before that my windows at the front start opening up at
higher speeds. Basically, I am restricted to 130 mph top speed now, as I can
pretty well stick a finger through the crack at that speed, and am afraid
something will pop if I go any faster.
I have the standard Murphy window with the latch in the middle, not near the
front as later builders have done. I would like to put in some kind of quick
to install latch/pin in the front to lock the window in place there. The key
phrase here is quick/simple to install. I am thinking of some kind of pin
that I can drop through the bottom of the fuse rib flange into the window
square frame. Any ideas?
It's not that I intend to fly this plane at that speed regularly, but would
like to run it a little harder for break-in, and also see just how fast this
thing will go with this engine. At 120 mph, it is just running 65% right
now.
Just to get you guys drooling a little more, thought I would mention my last
trip to the lake the other day. At take-off I was lightly loaded with fuel
at 1580 pounds, and there was only a very slight headwind on the water. As I
gave it full power, the nose/bows came up very quickly, and I was already
giving it full forward stick at about the same time as the engine spooled up
to full power. Then it immediately hopped up on the step, and it did a few
little bounces as I was trying to find the right attitude for the sweet
spot, but before I did, it was airborne. That was definitely the fastest
take-off I have ever done.
If you guys remember, too, when I installed my VGs, I had to modify my
take-off to start with neutral flaps. Not anymore, as it has enough power
now, to overcome the extra drag/lift of these VGs right from the start of
the take-off.
There is no question, this engine has a way more power than my old 320. And
that one was definitely no slouch as 320's go either. Really looking forward
to see what it does at the high altitude lakes this summer. BTW, for those
who are wondering, am carefully checking my tail after every flight.
Klatt
Sent: May 4, 2008 5:02 PM
To: Rebel-Builders
with the O-320.
only did 13 WOT.
climb though.
now.
the take-off.
Klatt
To: Rebel-Builders
with the O-320.
only did 13 WOT.
climb though.
At 07:35 AM 5/11/2008 -0700, you wrote:
running it as hard as I could. My engine broke in well and is running
great. My passenger window sucks open too in the winter I just run a piece
of duct tape up the front and halfway across the top.
Hi Walter I started leaning my new engine after only a couple hours ofAs I am breaking in my new engine, I am running it at full rich mixture, and
Thanks Drew. Weather was too crappy to fly today, so fixed up something that
should do the trick for me to keep the front of the windows tight. I riveted
a piece of velcro to the top frame near the corner, to attach up and around
the fuse flange. Definitely holds it solid, so will give that a try. Even
coils up tightly with Velcro back at the window, too, so it won't flap
around loosely when not in use.
Dalgleish
Sent: May 11, 2008 8:16 AM
Subject: RE: [rebel-builders] New engine is flying
Dalgleish
andAs I am breaking in my new engine, I am running it at full rich mixture,
soon.it is really putting through the fuel as I am trying to use enough power to
canHow many hours before I can lean normally? I have the ECI nickel carbide
thepretty well stick a finger through the crack at that speed, and am afraid
quickfront as later builders have done. I would like to put in some kind of
keyto install latch/pin in the front to lock the window in place there. The
Hi Walter I started leaning my new engine after only a couple hours ofphrase here is quick/simple to install. I am thinking of some kind of pin
bransom
I thought ECI advises now that there is no need for the high power ring
seating with their cylinders. I would find it hard not to do the more
traditional high power time myself, but what have you heard?
-Ben/ 496R
-Ben/ 496R
Dalgleish
At 07:35 AM 5/11/2008 -0700, you wrote:andAs I am breaking in my new engine, I am running it at full rich mixture,soon.it is really putting through the fuel as I am trying to use enough power to
With fuel prices the way they are, I would like to start leaning a bitcanHow many hours before I can lean normally? I have the ECI nickel carbide
higher speeds. Basically, I am restricted to 130 mph top speed now, as Ithepretty well stick a finger through the crack at that speed, and am afraid
I have the standard Murphy window with the latch in the middle, not nearquickfront as later builders have done. I would like to put in some kind ofkeyto install latch/pin in the front to lock the window in place there. TheHi Walter I started leaning my new engine after only a couple hours ofphrase here is quick/simple to install. I am thinking of some kind of pin
WALTER KLATT
No, I have not heard that. Where would I find that information. The break-in instructions that they send out and what I saw on their website are pretty general to cover all their types of cylinders.
Date: Monday, May 12, 2008 11:27 am
power ring
not to do the more
-Ben/ 496R
Behalf Of Drewrich mixture,Dalgleish
At 07:35 AM 5/11/2008 -0700, you wrote:As I am breaking in my new engine, I am running it at fullenough power toandit is really putting through the fuel as I am trying to useversion of theproperly seat the rings. I have the extra rich 10-4164-1leaning a bitO-360 carb so it is wasting about 3 gph in cruise by not leaning.
With fuel prices the way they are, I would like to startnickel carbidesoon.How many hours before I can lean normally? I have the ECIsupposed tocylinders (new high flow tapered fin exp cylinders) which areopening up atbreak in very quickly.
Also, I mentioned before that my windows at the front startspeed now, as Ihigher speeds. Basically, I am restricted to 130 mph topand am afraidcanpretty well stick a finger through the crack at that speed,middle, not nearsomething will pop if I go any faster.
I have the standard Murphy window with the latch in thesome kind ofthefront as later builders have done. I would like to put inthere. Thequickto install latch/pin in the front to lock the window in placekind of pinkeyphrase here is quick/simple to install. I am thinking of someinto the windowthat I can drop through the bottom of the fuse rib flangehours ofHi Walter I started leaning my new engine after only a couplesquare frame. Any ideas?running> great. My passenger window sucks open too in the winterrunning it as hard as I could. My engine broke in well and is
I just run a piece--of duct tape up the front and halfway across the top.
-----------------------------------------------------------------List archives located at: https://mail.dcsol.com/login
bransom
Walter,
I've heard it from a few sources that I regard as pretty solid, but now I
kind of forget where. IIRC, the change came a couple years ago. I just
skimmed ECI's web site and run-in vs break-in PDF
(http://www.eci2fly.com/pdf/BreakInInstructions.pdf), which is probably
what you have. I'll ask further on two of my sources, but yeah, getting it
pretty straight from ECI or their big-time builders seems the only
comfortable way to go.
-Ben
-Ben
break-in instructions that they send out and what I saw on their websiteNo, I have not heard that. Where would I find that information. The
power ring
not to do the more
-Ben/ 496R
At 07:35 AM 5/11/2008 -0700, you wrote:enough power toandversion of theleaning a bitnickel carbidesoon.supposed toopening up atspeed now, as Iand am afraidcanmiddle, not nearsome kind ofthethere. Thequickkind of pinkeyinto the windowhours ofHi Walter I started leaning my new engine after only a couplerunning> great. My passenger window sucks open too in the winterrunning it as hard as I could. My engine broke in well and is
JBCressman
Hi There--My Rebel (331) has one pin at the front of each window installed
exactly as you suggested
and readily solved the window opening in cruise problem. Bob Cressman
