Two AN140-16S assemblies (cable eyes) should do the trick Ted. 1/8 cable is
rated at 2000lbs and the -16S assembly is rated at 1600 lbs so the
turnbuckle is the weak point but they'll never see 1600 lbs. Go up to the
-22S if you feel you must. Don't forget to get some AN100-4 cable thimbles
and 18-3-M nicopress sleeves. Cut the pointy ends off of the thimbles
before crimping the sleeves. Three crimps per sleeve. First one in the
middle, then the two outer ones, if I remember right. Slide some shrink
wrap over the cable before you crimp so you can cover up the cable ends if
you want.
044SR
Waltman
Sent: Sunday, March 16, 2008 9:26 AM
Subject: [rebel-builders] Turnbuckles
Going to order two turnbuckle assemblies today. Thought it would be an easy
process <sigh>.
I'm looking on-line at Aircraft Spruce & Wicks (better drawings) at the
admittedly bewildering variety of turnbuckle assemblies and part #'s.
http://www.wicksaircraft.com/catalog/pr ... index.html
Hopefully someone can save me a whole lot of heavy-duty head scratching.
These will be used for my rudder cables.
. Since turnbuckles come in a variety of strength ratings, how
strong is strong enough for the rudder cable assembly
. When would one use an AN-165 pin eye versus an AN-170 Cable-Eye
versus an AN-161 Turnbuckle Fork?
. What are the pro/cons of simply attaching the cable with a thimble
through the eyebolt of the turnbuckle (e.g. AN-170 cable eye) versus using
an AN-161 turnbuckle fork on one end
. Will an AN-111-4 cable bushing will fit between the tines of an
AN-161 turnbuckle fork?
Geesh, science project <grin>
Thank you for your input!
Ted Waltman
