VIRUS-OPEN THIS MAIL ABSOLUTELY FIRST BEFORE OTHERS!
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:57 pm
Your following message has been delivered to the 157 members of
the list murphy-rebel@dcsol.com at 09:08:21 on 5 Sep 2000.
Sam and Sandi's Mail Contains a WScript.kakWorm and so does my response to
their mail labeled VIRUS ALERT OPEN BEFORE SAM and SANDI's MAIL.
DO NOT OPEN EITHER MAIL
WAYNE
Post by Walter Klatt » Fri Feb 17, 2012 5:57 pm
<!doctype html public "-//w3c//dtd html 4.0 transitional//en"> Wayne and all. Unfortunately, I opened Sam and Sandi's email before I read this note, and potentially was at risk with the virus. I checked it out further and downloaded a fixkak program from the following website to check my computer and clean it if it was infected.
Wscript.Kakworm Fix
If you have it, it will confirm that and clean it out and fix the damage. If you don't, it will tell you, too, and give you piece of mind. One more thing, I was also told that the virus may not take affect until after a reboot, so you might want to run it after that, too.
In my case, I didn't have it, probably because my anti-virus DAT files are fairly up todate, or it didn't exist.
So if any of you don't have the latest virus software in place, or just want to confirm that you don't have the virus, you can download and run the fix.
WAYNE
