root rib attach bracket
Jones, Mike
Post by Jones, Mike » Fri Feb 17, 2012 5:57 pm
Hi all
Have a question on the fitting for the root rib attach bracket.
Is the roo rib attach bracket (w-161) supposed to end flush with the front
spar. Mine over hangs the spar by 1/16". This however allows the root rib to
be straight and square with the leading edge skin.
On mine if the w-161 was flush with the leading edge skin the root rib would
have to be on an angle and the upper and lower holes on the flanges of the
root ribe would not follow the center lines.
Any sggestions as to the right way to do this???
Mike#007
EOM
NOTICE - This message is the property of HATCH. It may also be confidential
and/or privileged. If you are not the intended recipient of this message
you are hereby notified that you must not disseminate, copy or take any
action with respect to it. If you have received this message in error
please notify HATCH immediately via mailto:MailAdmin@hatch.ca.
klehman
Post by klehman » Fri Feb 17, 2012 5:57 pm
Hope I didn't misunderstand you on this, but yes all my root ribs are
flush with the inboard edge of the skins. On my right wing, the W-161
bracket extends past the rib and skin by about 1/16" exactly as you have
described below. On my left wing, the W-161 extends out perhaps 1/4" and
the packer extends even further.
Hopefully someone else will answer this as well so you have another
comparison.
"Jones, Mike" wrote:
Hi all
Mike#007
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:57 pm
Your following message has been delivered to the 157 members of
the list murphy-rebel@dcsol.com at 12:14:39 on 5 Sep 2000.
Guys, you are doing it correct! Rib straight, W-161 and packer where every
they need to be to keep the rib straight!
Blue skies,
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Sent: Tuesday, September 05, 2000 8:53 AM
Subject: Re: root rib attach bracket
comparison.
Hi all
front
rib to
would
Mike#007
