[rebel-builders] Moose: Baggage area extension
Posted: Sun Feb 19, 2012 7:26 pm
Hi Ted
I am about to start the same task of adding inside corner wraps top and bottom.
What material thickness (assuming 6061-T6 Al) did you use for the wraps?
How did you pre-bend them?
Jack Joos SR193
Jack Joos SR193
Murphy recommends that if you're not putting in the rear baggage door (I'm
not) then you should extend the top corner wraps (normally only between
bulkheads A & C on both sides) to bulkhead D (or E). So I figured I might
as well add bottom wraps too. Then I figured since I'm fabricating the
additional channels (20 total!) I might as well add a few more and add them
to the floor. Then I can extend my baggage area (only for very light-weight
stuff such as sleeping bags and clothes) to bulkhead E. Almost 40 hours
later I'm almost done (ha!) with this modification. I will have to add some
slot and corresponding cover to the rear of the floor extension in the very
rear to allow for the elevator & rudder cable runs. I still have to nut
plate the floor to the floor channels. I'll have retaining nets/fabric of
some sort attached to the E bulkhead as well as the B bulkhead when
finished.
3 Pics in area 109 - S/M-Interiors.
Ted
