Moose: Baggage area extension
Posted: Sun Feb 19, 2012 7:26 pm
Murphy recommends that if you're not putting in the rear baggage door (I'm
not) then you should extend the top corner wraps (normally only between
bulkheads A & C on both sides) to bulkhead D (or E). So I figured I might
as well add bottom wraps too. Then I figured since I'm fabricating the
additional channels (20 total!) I might as well add a few more and add them
to the floor. Then I can extend my baggage area (only for very light-weight
stuff such as sleeping bags and clothes) to bulkhead E. Almost 40 hours
later I'm almost done (ha!) with this modification. I will have to add some
slot and corresponding cover to the rear of the floor extension in the very
rear to allow for the elevator & rudder cable runs. I still have to nut
plate the floor to the floor channels. I'll have retaining nets/fabric of
some sort attached to the E bulkhead as well as the B bulkhead when
finished.
3 Pics in area 109 - S/M-Interiors.
Ted
finished.
Ted
