[rebel-builders] Dry oil sump and engine questions
Post by Ken » Sun Feb 19, 2012 4:26 pm
Mike Kimball wrote:
I would like to seek learned opinions from you guys about a couple of
things. First, I finished constructing a dry oil sump for my PSRU. I made
it out of 3" foam core ABS plastic pipe. My PSRU has an integral oil pump
and I have a pressure gauge in the cockpit that tells me that the max
pressure it sees is about 20psi and is usually closer to 10 psi. I'm not
sure if the oil outlet is subject to that pressure or is just in a
non-pressurized area of the unit but I would expect to see very little
pressure in my sump. A web search tells me that foam core ABS is for
non-pressure applications where the temp will not exceed 160F. I've seen
engine oil temps a bit over 200F but I think I can get those to stay under
200F. The PSRU is not directly subjected to combustion temps like the block
so I would think that it would run cooler using it's own dry sump. (Might
have to see about fitting a temp gauge on it.) Especially since it is in
the front right behind two holes in the cowl for cooling air to enter. The
placement of my sump will put it right in the path of that cooling air as
well. ABS sump a bad idea? There's the issue about the ABS adhesive that
holds the caps on too. PVC is even worse with a 140F max temp
recommendation. Aluminum is impossible for me to make myself. Can't find
anything suitable off-the-shelf.
Hi Mike
Oil can burn! Your exhaust headers glow very brightly. There is no place
for low temperature plastic under the cowl IMO. I even went to teflon
tubing (500*F) for my psru sight gauge and mine only has about 9 ounces
of oil in it with no pressure. I'd suggest welding up a custom tank if
necessary. You want a good margin of safety here for hot day climbs or
other issues that might raise the temperature. I only have air blast
cooling but I have seen 212+F psru oil temps. A couple of percent of
engine power is being converted to heat in the psru.
You might remember that my #8 exhaust valve seems to be leaking. Leak down
test shows low compression and I hear air leaking out the exhaust pipe. I
double checked the leak down with the rockers removed to be sure the valves
were closed. Very low hours on the engine since rebuild (after my burned
piston). Maybe 10 hours total, ground and in-flight. Tried smacking the
valve with a plastic hammer to see if some carbon or something was holding
it open with no luck. I had a very good engine shop disassemble, inspect,
and reassemble the heads after the burned piston event just to be sure
everything was OK. Is there any chance of improvement with more time on the
engine or should I just dive into pulling the head to check out the valve?
Or is there something else that can be tried before pulling the head?
I'd defer to anyone with experience with that particular engine but I
can't think of any scenario where it might improve. More likely is
further degradation perhaps on multiple cylinders if there is a common
cause.
Another somewhat related question. When I first built the engine, and again
after the rebuild I am getting lower compression readings on all the
cylinders than I would expect. Inputing 80 psi I get low 60s on all
cylinders (except #8 which gives me low 30s right now). I tried two
different testers (one automotive and one from Aircraft Tool Supply) and get
the same readings. I am very careful finding TDC and even try to get the
numbers up a bit with a bit of nudging on the prop (I've had luck with this
on Lycomings). I am careful to come up to TDC in one direction and then not
reverse to try and seat the rings on one side of the groove. Is there
something about my Chevy V8? Do the rings need more time to fully seat?
The engine is running great and developing good power.
I think you know this and it is not relevant but an actual COMPRESSION
reading depends on cranking speed somewhat and throttle fully open.
Usually I see higher readings than the compression ratio would suggest
because in the real world the charge is also heated when it is
compressed. Adding a bit of oil will raise the pressure if it is ring
leakage of course.
However it sounds like you are actually doing a LEAKAGE check with
compressed air here. Sure sounds like you have had a valve problem with
#8 since new. Based on what you've said I would not suspect a ring
issue. Ring leakage is usually quite audible with your ear to the oil
filler. It can sometimes be tricky to get a leakage checker to seal in
the spark plug hole but again you can hear that leakage. Sorry but
there is a definite problem here.
I like to do a very light hand lapping of valves so I can see the
sealing surface or at least confirm the valve seating with some
machinist blue. That also checks for bent valves or mis-aligned valve
guides. Everybody has a bad day though and another possibility can be a
bent valve after installing the heads on engines with interference
pistons and valves. Doesn't take much to do damage before getting the
camshaft timing correct...
Thanks in advance guys.
Post by Drew Dalgleish » Sun Feb 19, 2012 4:26 pm
Hi Mike Like Ken I don't think that an ABS sump is a good solution either.
I think that over time the hot oil will harden the plastic to the point
that it will crack. I've seen air oil separators made by welding fittings
onto an old propane cylinder would that work? For an aluminum tank maybe
this would work
http://store.summitracing.com/partdetai ... %2D63651&N
=700+115&autoview=sku
On your #8 exhaust valve before pulling the head I'd try lapping the valve
in place using the rope trick.
Are you checking compession with the engine fully warmed up? A cold engine
will give low readings.
Post by Mike Kimball » Sun Feb 19, 2012 4:26 pm
Thanks Ken and Drew. I managed to forget about the proximity to the
headers. And the info about the PSRU oil temp on Ken's plane clinches it.
I hadn't run across that expansion tank in my web searches Drew. That just
might work. Also, I was doing compression checks on a cold engine. Very
good point. I'll check again on a hot engine. How do you lap a valve in
place? Thanks again guys.
Sent: Friday, February 29, 2008 4:08 AM
Subject: Re: [rebel-builders] Dry oil sump and engine questions
made
block
The
Hi Mike
down
valves
cause.
again
get
this
not
leakage of course.
Thw rope trick for lapping valves in place. It occurred to me after I wrote
that it might be really hard to do with only 1 18mm spark plug hole I've
only done it on lycoming engines but I'll explain it anyways.
safety first remove all the spark plug wires then remove the spark plug
and turn the engine till the piston is near the bottom. push as much of a
peice of rope ( 1/2" cotton is ideal but anything will work ) as you can
into the cylinder. Now turn the prop to bring the piston up and squish the
rope up into the head. Now you can take off the rocker arm. For lycomings
there's a neat tool to compress the valve spring enough to remove the
keepers. I guess on your chevy you'll have to figure that part out
yourself. Basically you need a lever about a foot long that presses on the
spring on both sides while leaving enough room to get the keepers out. Some
sort of a fork that bolts on where te rocker arm came off. After you get
the valve spring off you can attach your lapping tool then turn the prop
back enough that you can pull the rope out of the cylinder then push the
valve down far enough to see and paint the lapping compound on through the
spark plug hole then lap the valve and reassembe using the same tecknique.
Oh yeah I never had much luck with those lapping tools that just turn the
valve back and forth a little bit so I just use my cordless drill with a
peice of rubber hose attached to a drill bit and the valve stem to spin the
valve.
made
block
The
Hi Mike
down
valves
cause.
again
get
this
not
leakage of course.
Great idea for cleaning up carbon or a very lightly eroded seal surface
but don't think it will help on a new engine with serious leakage since
new. 30 psi is very serious leakage and that sealing surface supposedly
is fresh and clean.
Sorry to be a pessimist but methinks there is more to this.
valve.
Dan
Post by Dan » Sun Feb 19, 2012 4:26 pm
Have done the same 3 times, works well...one of those little led lights that
u can stick in the plug hole help to ck out progress...Noticed egt temps
jumping around on particular cyl, and compression ck indicated, not so good
a seal...and this was the easiest way to fix problem..A good rinse with some
light oil, will get compound out of cyl thru lower plug hole...
I am using the free version of SPAMfighter for private users.
It has removed 751 spam emails to date.
Paying users do not have this message in their emails.
Get the free SPAMfighter here: http://www.spamfighter.com/len
