[rebel-builders] CC-102 rudder pedal torque tubes
Posted: Sun Feb 19, 2012 7:26 pm
by Ken
Jason
My Rebel pedal torque tubes are all 90 degree weld joints. And they both
will lay flat on a table. No twists anywhere.
Jason Beall wrote:
Guys,
The stickers have come off of my CC-102L and 102R
rudder pedal torque tubes.
If you turn the tubes end on and look down the long
axis, one tube has the crank arm parallel to the
rudder pedal shaft. The other has an approximately 25
degree angle difference between the crank arm and the
rudder pedal arm.
Can someone please help me identify these? Can someone
also please tell me which way the sweep faces on the
arm with the 25 degrees bend? Forward or aft?
Thanks, -Jason
