Float Hard Point Installation
Post by Mike Davis » Fri Feb 17, 2012 7:21 pm
Received: from MMoreho699@aol.com
by imo13.mx.aol.com (IMOv14.1) id GRMKa29777;
Mon, 27 Apr 1998 22:53:06 +2000 (EDT)
Message-ID: <1fb6b00c.35454493@aol.com>
Date: Mon, 27 Apr 1998 22:53:06 EDT
To: murphy-rebel@dcsol.com, murtech@murphyair.com
Mime-Version: 1.0
Subject: Float Hard Point Installation
X-Mailer: AOL 3.0 for Mac sub 78
Got some questions.
Here's how I interpret or don't interpret MAM's instructions for the float
h.p. installation from manual 07/27/94 for the Rebel:
Steps 1-5 concern themselves with making a hole in the rolled corner for
float bracket to stick through. Done that.
6-8 I drilled holes in the bracket through the original bulkhead 'A'.
9-14 I nested two additional bulkheads together, reversed them and drilled
holes through them from bulkhead 'A' and the bracket.
15 I've postponed riveting the bracket to the three bulkheads.
16 drilled holes at the top of the two nested float bulkheads
17 postponed riveting these together
18, 19 MAM says to drill holes through the 'new' bulkhead flange into the
sides, corners, and floor. Is 'new' the doubled float bulkheads?
20 made a cover strip for the three bulkheads
21 'Drill and rivet into the flanges of the bulkheads....' Is this about
connecting the strip to the three bulkheads?
So it seems that the nested float bulkheads are riveted to the sides,
corners,
and bottom skins. They are also riveted to bulkhead 'A' at their tops
directly
as well as indirectly at the rolled corners via the float bracket.
I have nearly completed the framework for the inner floor. Could I at this
time attach the floor channel brackets to the nested float bulkheads? Where
and when do I attach the floor inner panel (fus 41) and the floor corner
wraps
(fus 33)? To the float bulkhead or bulkhead 'A' or both?
I don't see any drilling or riveting between Bulkhead 'A' and the fuselage
skins. I assume this will come later.
Phew!! (That came out of my lungs, not the lower gastrointestinal tract!) I
think that does it. Really appreciate your input.
Dan
Received: from tim - 208.250.191.246 by email.msn.com with Microsoft
SMTPSVC;
Tue, 28 Apr 1998 10:03:44 -0700
Received: by localhost with Microsoft MAPI; Tue, 28 Apr 1998 10:00:35 -0700
Message-ID: <01BD728C.7D2C8720.tlcarter@email.msn.com>
Reply-To: "tlcarter@msn.com" <tlcarter@msn.com>
To: "'murphy-rebel@dcsol.com'" <murphy-rebel@dcsol.com>
Subject: RE: Float Hard Point Installation
Date: Tue, 28 Apr 1998 09:36:31 -0700
X-Mailer: Microsoft Internet E-mail/MAPI - 8.0.0.4211
MIME-Version: 1.0
Return-Path: tlcarter@email.msn.com
Have you called Murphy Tech Support? I find that they are great for
clarifying the manual. Robin Dyck is the most knowledgeable if you can get
him.
Tim
Reply To: murphy-rebel@dcsol.com
Sent: Monday, April 27, 1998 7:53 PM
To: murphy-rebel@dcsol.com; murtech@murphyair.com
Got some questions.
corners,
directly
wraps
Dan
by imo16.mx.aol.com (IMOv14.1) id GINOa29937
for <murphy-rebel@dcsol.com>; Tue, 28 Apr 1998 13:38:45 -0400 (EDT)
Message-ID: <f814e773.35461426@aol.com>
Date: Tue, 28 Apr 1998 13:38:45 EDT
Mime-Version: 1.0
Subject: Re: RE: Float Hard Point Installation
X-Mailer: AOL 2.7 for Mac sub 3
Thanks Tim! I have talked with Robin before. I sent a copy of the email to
MAM. Dennis has been answering questions. If I'm in a hurry or can't
understand email responses, I call.
Dan
Received: from [205.163.8.199] (drk.cts.com [205.163.8.199]) by mh2.cts.com
(8.8.7/8.8.5) with ESMTP id UAA22428 for <murphy-rebel@dcsol.com>; Tue, 28
Apr 1998 20:00:09 -0700 (PDT)
Date: Tue, 28 Apr 1998 20:00:09 -0700 (PDT)
X-Sender: drk@crash.cts.com
Message-Id: <l03110700b16be3b27a3a@[205.163.8.199]>
Mime-Version: 1.0
Dan or anyone else following these posts;
Can you receive e-mail attachments? I would like to post a JPEG style file
that shows my float attachment point. It may answer a lot of questions, and
maybe raise a few more.
Rebel #472
Dave Klimas
Ramona, CA
(8.8.7/8.8.5) with ESMTP id UAA26768 for <murphy-rebel@dcsol.com>; Tue, 28
Apr 1998 20:35:55 -0700 (PDT)
Date: Tue, 28 Apr 1998 20:35:55 -0700 (PDT)
Message-Id: <l03110702b16be6531833@[205.163.8.199]>
Mime-Version: 1.0
Dan,
The "new" bulkhead (flanges facing aft) sits immediately aft of bulkhead
"A" with the float hardpoint bracket between the two in the center of the
lower corners of the two bulkheads.
I have the main tailcone riveted together up to but NOT including bulkhead
"A", the "new" float hardpoint bulkhead and all four corner wraps that
attach to bulkhead "A". All of these will be assembled after I finish
clecoing the forward cabin area to the tailcone section. The main reason
for doing the assembly this way is because there are a lot of different
parts coming together at bulkhead "A" and I want to drill the final #30
holes thru everything at once. The easiest way for me to do this is to lay
each piece in place, drilling (3/32) and clecoing as I go. I find this most
important at those joints that have three or more pieces coming together.
Rebel #472
Dave Klimas
Ramona, CA
Received: from tim - 153.35.236.107 by email.msn.com with Microsoft SMTPSVC;
Wed, 29 Apr 1998 11:42:09 -0700
Received: by localhost with Microsoft MAPI; Wed, 29 Apr 1998 11:38:39 -0700
Message-ID: <01BD7363.5A5DDFA0.tlcarter@email.msn.com>
Date: Wed, 29 Apr 1998 11:35:02 -0700
MIME-Version: 1.0
I can. Please send it. I'd like to see it. I should be getting to that
point soon.
Tim
Sent: Tuesday, April 28, 1998 8:00 PM
Rebel #472
Dave Klimas
Ramona, CA
Received: from d.james (ba2p24.planeteer.com [204.50.144.89])
by toronto.planeteer.com (8.8.7/8.8.7) with ESMTP id WAA13496
for <murphy-rebel@dcsol.com>; Wed, 29 Apr 1998 22:50:32 -0400 (EDT)
Message-ID: <3547E798.9C620115@planeteer.com>
Date: Wed, 29 Apr 1998 22:53:13 -0400
X-Mailer: Mozilla 4.01 [en] (Win95; I)
MIME-Version: 1.0
Subject: Re: Float Hard Point Installation
X-Priority: 3 (Normal)
References: <l03110700b16be3b27a3a@[205.163.8.199]>
X-Corel-MessageType: EMail
file
questions, and
I think most people can receive attachments although some service
providers have limits on file size, someone sent a AutoCad drawing
around to the AirSoob subscribers and it crashed a lot of servers and
the List sysop took a lot of heat. Keep the file small and there
shouldn't be a problem, the threshold of my provider is about 400K.
Please post it to the group.
David James
Rebel 228
Received: from sas(dialup111.toledotel.com[204.245.211.160]) (1025 bytes) by
inet1.toledotel.com
via sendmail with P:esmtp/R:inet_hosts/T:smtp
(sender: <sas@toledotel.com>)
id <m0yUkmB-000DL2C@inet1.toledotel.com>
for <murphy-rebel@dcsol.com>; Wed, 29 Apr 1998 21:16:51 -0700 (PDT)
(Smail-3.2.0.101 1997-Dec-17 #3 built 1998-Feb-22)
Message-Id: <m0yUkmB-000DL2C@inet1.toledotel.com>
Date: Wed, 29 Apr 1998 21:13:08 -0700
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Howdy Dave, That was sure a great photo of your hard point mount. You guys
are further along than us, but sure enjoy the dialog. sAs Elite # 556
Date: Wednesday, April 29, 1998 8:36 PM
Here is the JPEG photo of the current state of my float hardpoint
attachment.
The attachment is about 40K, JPEG 25:1 compressed color file.
Feedback/comments welcome.
Rebel #472
Dave Klimas
Ramona, CA
Received: from chucks.gte.net (1Cust180.tnt1.krk1.da.uu.net
[153.37.232.180])
by smtp2.mailsrvcs.net with SMTP id XAA06584
for <murphy-rebel@dcsol.com>; Wed, 29 Apr 1998 23:39:25 -0500 (CDT)
Message-ID: <001e01bd73f1$8acf5cc0$b4e82599@chucks.gte.net>
Date: Wed, 29 Apr 1998 21:36:26 -0700
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-Mailer: Microsoft Outlook Express 4.72.2106.4
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.2106.4
Great pictures. Hope anyone else who has photos to share will post them.
Thanks.
- Chuck Skorupa -
To: murphy-rebel@dcsol.com <murphy-rebel@dcsol.com>
Date: Wednesday, April 29, 1998 8:51 PM
attachment.
Rebel #472
Dave Klimas
Ramona, CA
Float Hard point Installation
(8.8.7/8.8.5) with ESMTP id UAA18808 for <murphy-rebel@dcsol.com>; Thu, 30
Apr 1998 20:15:36 -0700 (PDT)
Date: Thu, 30 Apr 1998 20:15:36 -0700 (PDT)
Message-Id: <l03110703b16e88c7723c@[205.163.8.199]>
Mime-Version: 1.0
Subject: RE:RE:Float Hard point Installation
Hi Tim et al;
(1) I'm using the MAM supplied primer Stits Poly-Fiber EP-420. First I try
to alodine everything I can get into sections of plastic rain gutter, which
is just about every thing but the skins. I scotch-brite the insides of the
skins and spray a light coat of the EP-420. Seems to work OK. I'm a novice
at spray painting (actually at most of the things I find myself getting
into with the Rebel), so some spots didn't adhere as well as I thought
epoxy should. My main objective is to make sure all overlapping parts and
joints are sealed with primer. I do not plan to prime the innards of the
wings, just the fuselage.
(2) No, they were solid. I made a simple plywood fixture for the drill
press and with a 1-1/4 inch hole saw drilled holes on about 2-1/4 inch
centers. I made a simple aluminum "punch and die" that I put in each hole
and squeezed them together in a bench vise. Adds a little time but looks
great, and the flange actually makes them quite a bit stiffer. I will
probably limit this to the "optional" flooring areas.
Rebel #472
Dave Klimas
Ramona, CA
Hi Dave:
I like Ramona. The rock outcroppings there are reallay a beautiful sight
from the air.
Anyway, I received your Rebel picture. I have two questions:
1) What promer are you using?
2) Did your 2" channel for use under the floorboard come with those
lightening holes in it, or did you do that yourself?
Tim Carter
#438R
Sac, Ca
