[rebel-builders] Rebel - Fus 10
Posted: Sun Feb 19, 2012 7:21 pm
by Bob Patterson
Hi Peter !
Somewhere in the past 10 years, Murphy started shipping
FUS-70's for the lower front 2 corner wraps. The original FUS-10's
were .020, and adequate, if you didn't dent them.... I had a small
dent in mine that turned into a 3" crack within a month !!
Many builders now order their kits with ALL of the FUS-10's
upgraded to FUS-70's (8 total) - adds a little weight, but Wayne has
observed several Rebels with crushed upper rear FUS-10's,
after VERY hard landings .... A worthwhile upgrade if you
haven't reached that point in building yet.
The factory also have even heavier corner wraps - .032 -
for the Elite. Think these are FUS-454 (???) - some have tried
to use these on the Rebel, but found the stiff metal a bit too hard
to work with.... FUS-10, FUS-70, and FUS-454(??) are ALL
the same size & shape.
One Ontario mod you might want, though, is to replace the
FUS-26 - flat panel below the door - with a copy in .032 or
.040, plus adding a couple of vertical stringers or channels
to the inside, to stiffen it up. This area bows out on floats ....
(Some builders just epoxy & rivet a second FUS-26 over
top of the original.)
bobp@prosumers.ca
http://www.prosumers.ca
On Tuesday 22 January 2008 12:21, petergibbs@dcsol.com wrote:
Hi does anyone know of a reason or mod to change the thickness of the
fus 10 wrap on lwr fus below the door, my 235 Rebel has had one previous
accident and these have been replaced with 25 thou from 20, or was it a
MAM mod?
have searched archives without success
any help appreciated ,Peter.
by Jean Poirier
On the upper rear fus-10, I made a doubler (out of a .020" corner wrap) +/-
60% of the surface ( on width) of the fus-10. I riveted it over the
original part. Much more stiff now.
Jean
Rebel 747R
Jean Poirier
Pr
by peter gibbs
Thanks Bob, and Jason, Jean , Ken,
clears that up for me, Iam on spring gear so no probs, I have fus 70 behind
the firewall all the rest will be 20 thou fus10s thanks again Peter
Sent: Tuesday, January 22, 2008 2:20 PM
Subject: Re: [rebel-builders] Rebel - Fus 10
Hi Peter !
bobp@prosumers.ca
MAM mod?
