[rebel-builders] stringer orientation
Posted: Sun Feb 19, 2012 7:17 pm
by Ken
Dieter
I can't think of any reason it would matter which way the stringers
pointed. Hope they are on the interior side of the skin though...
Dieter Oberbichler wrote:
hello list !
Another error in a series of so many, and I can't blame the manual...
I just noticed that my stringers on the bottom wing are either on the outside ;-( or facing in the wrong direction. I assume that external stringers are not an option, but what about the orientation ? Does it matter it these two stringers face forward with their open end? I really hope it doesn't !
I didn't find anything in the archives about it, maybe someone out there knows how important the orientation is.
Thank you Wayne for the tip with the file for deburring the stringers, that saved me a lot of time!
BTW, I use plastic containers we normally used for submitting cattle brain samples to the state-lab for "mad cow disease testing" for my epoxy primer ....who can beat this :-))
thanks
Dieter
Rebel 778R
many more rivets to pull.....
http://www.mykitlog.com/oberbichler
by Dieter Oberbichler
Thank you Ken, that was the answer I was looking for!
Dieter
778R
Sent: Monday, January 07, 2008 6:11 AM
Subject: Re: [rebel-builders] stringer orientation
Dieter
hello list !
hope it doesn't !
thanks
Dieter
Rebel 778R
by Drew Dalgleish
Hi Dieter I don't think it matters either but if you used that skin for
your second wing they'd be facing the right way.
Dieter
778R
Dieter
hello list !
hope it doesn't !
thanks
Dieter
Rebel 778R
Posted: Sun Feb 19, 2012 7:21 pm
by Ken
Don't think you can swap sides as the rivet spacing is different on the
inboard and outboard ends of the skin.
Dieter
778R
by Drew Dalgleish
Opps My bad For some reason I was thinking that the rivet spacing was only
different on the leading edge skin.
Dieter
778R
by d.oberbichler
Dr.Dieter Oberbichler
Tier
