each side of them for a total of FOUR on each side. This is where the rear
wing attach fitting will slide INTO these fuselage fittings.
Sent: Wednesday, January 02, 2008 2:46 PM
Subject: [rebel-builders] wing attach brackets...
Hello
Manual ask to trim ( fuselage-69) the "two inner brackets" as in
figure12.26.3 Is that mean one on each side (right and left wing) or
two on
each side. Also, "inner fittings" is that mean the ones on the door side
(not on the tail side)? As you see my english is far from perfect and
am not sure if I understand well what the manual ask for
Jean
Rebel 747R
