[rebel-builders] Click Bond nutplates
Posted: Sun Feb 19, 2012 7:17 pm
Ralph,
I have thought of "remote mounting" in that way a few times, but haven't
done it yet. You put the adhesive on the mating surface of the nutplate
first, and it does set up pretty quickly, so I think you'd want to
practice the threading operation a time or two first, at least to the
point of just starting the silicone rubber stick into the hole.
Another problem may be that the adhesive requires a fairly clean
surface. The small batch adhesive kits come with a little wipe of
special humdinger solvent that's used to clean the surface. In a hard to
reach spot, you may be able to dab off light dust or dirt with a stick
of some kind, but removing previously applied chromate or other primer
might be tough. If there may be a problem preparing the surface, check
with the dealer. They may have a technique you could try.
One other general caution: the small adhesive packs have expiration
dates. They're for real. I once tried to use one that was 6 mos. past
expiration. The adhesive didn't have the usual powerful aromatic whiff
going on <g> and sure enough, it was the only time I've had a failure.
It took a lot of heat from the heat gun to clean it off and start over
with fresh adhesive.
All that aside, for a standard nutplate application, where you can get
at the application side, these things are a snap to use.
Obviously, I'm a big fan. I plan to use the tie wrap pads for wiring --
much stronger than the stick on type. I also may use the small nutplates
for wing/elevator/rudder tip attachments under the metal soon, and will
test the "hole protector" grommet rings for the top of the composites,
under low profile flat or oval head screws.
Ralph Baker wrote:
Ralph Baker wrote:
Ron,
I think you just saved me about 30 hours! My left wing flap and aileron hinges were overtorqued (memory crash) and I have put off fixing it because of the access dificulty. Now, with the nutplates it looks like I can thread a pull line from outside, attach it to the nutplate stem and pull it through without additional metal work. Success to be determined but it is a bright ray of hope. Yipppeeee!
Happy New Year all!
