Rebel from "Down Under"
Posted: Fri Feb 17, 2012 8:57 pm
There have been some discusions on this which should be in the archives
but my memory is that yes a wee bit of toe in (one degree or so) is
probably good, toe out is not good. I have no personal experience either
way.
The Flying Rebels List is for the discussion between
builders and owners of complete/flying Murphy Rebel
aircraft. Archives located at:
way.
*-----------------------------------------------------------------------------------*Rick Harper wrote:
Anyway, ..I keep hearing stories from various sources that "one or two
degrees" toe IN
is required in several tail draggers.
As far as I can see, the plans show the axles at 90 degrees to the
side of the fuselage...
in other words "dead true" and with NO toe in.....
What is the expected "norm" here ?
