Angled oil filter adapter
Post by Walter Klatt » Sun Feb 19, 2012 4:10 pm
I have the new angled oil filter adapter on my new 360 engine. I am not sure
if it will fit with the dynafocal mount though. What have others used? Did
you have to get an extension for your adapter to move it out a bit to fit
around the mount?
Drew, I vaguely recall that you had one of these with your new engine? Did
it fit OK?
gleeso
Post by gleeso » Sun Feb 19, 2012 4:10 pm
FWIW, I have the B&C filter adapter on my PA 22 with conical mounts.
There is not much room on the Tripe but with the 1.25 spacer it's fine.
Not sure how much room on a Rebel with a Lyc, but it couldn't be much
tighter than the Tripe. I have some pics if anyones interested. BTW also
have flexible oil hoses, not the solid pipes.
Hope it's not too cold over there,
Regards
John Gleeson
Rebel 804 down under
