[rebel-builders] laser tape measure
Post by Wayne G. O'Shea » Sun Feb 19, 2012 4:10 pm
That'd really scare the crap out of the drug runners on night landings.....
and you too when the bullets come up thru the floor. I'd rather be looking
side ways out the window at the shoreline than staring at a readout when
above the water Garry.
Sent: Thursday, November 22, 2007 12:02 PM
Subject: [rebel-builders] laser tape measure
Walter Klatt suggested the use of a laser tape measure as a low level
(below 100') altitude device. You can get these at Home Depot for about
$99US.
Does anyone know if these tape measures (laser not sonic) will bounce
properly off water and indicate altitude above the water?
Has anyone done this?
Garry
068R C-FOKM
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 4:10 pm
I did?? But sounds like something I could have used a few times...
Are you thinking of having that in case of getting caught with an engine out over glassy water?
Walter (must not forget to take my AZ pills)
Date: Thursday, November 22, 2007 9:09 am
level
for about
$99US.
bounce
Garry
068R C-FOKM
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 4:10 pm
Wayne and Walter,
Yes Wayne, you're right about eyes out - I was thinking of a HUD
arrangement which I also don't know how to rig yet. Walter, after one
glassy incident I want to load the deck in my own favor if I can without
spending enough for a moonshot. I think it was you made this suggestion
- maybe not. What's an AZ pill or am I showing my age - again?
Garry
level
for about
$99US.
bounce
Garry
068R C-FOKM
The other question would be is the lazer going to pick itself up for read
out when you're doing 65/70MPH. If it was straight out front at a brick
wall sure..but straight down..you may be leaving the rebound info beam
behind. Only one way to find out...
Sent: Thursday, November 22, 2007 1:04 PM
Subject: Re: [rebel-builders] laser tape measure
Wayne and Walter,
Garry
level
for about
$99US.
bounce
Garry
068R C-FOKM
WALTER KLATT
AZ was my personal abbreviation for Altziemers. Anyway, don't think it was me, but like I said, an interesting suggestion.
I still recall a few years ago trying to fly in low cloud and fog up the coast here on one of our Wings Over Canada escapades. When I unexpectedly touched the water at 70 mph, I decided it was time to land. Glassy water is one thing, but also no horizon is another. Anyway we turned around then and flew back to where we found a hole, and then went over top.
Then another time was trying to get into Tofino on the west coast of the Island and running into low cloud and fog ahead. My wife was with me that time, so didn't hesitate in turning back before I had to get too low. However, as I was hugging the shoreline, had to turn away to open sea for the 180, and still remember a brief moment where I had no horizon ahead, and hard to tell exactly how high I was off the water. Did a couple of glances to my turn and bank just to make sure. And my wife never did notice the extra beads of sweat that suddenly appeared on my forehead.
Date: Thursday, November 22, 2007 10:04 am
Wayne and Walter,
after one
without
suggestion
Garry
low
level
for about
$99US.
will
bounce
Garry
068R C-FOKM
David Jackson
Post by David Jackson » Sun Feb 19, 2012 4:10 pm
1. The laser is travelling at the speed of light. You are not going to leave the reflection behind.
2. Worst case is glassy water that is clear, like some mountain lakes. The beam might not reflect enough off that water. If you are depending on the laser to get you down safely you might end up as a statistic.
3. I would stick with using the proven glassy water techniques taught with the seaplane rating. They work.
4. There may be legal consequences if the laser is inadvertently shone into another aircraft.
Dave J
From: oifa@irishfield.on.ca> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] laser tape measure> Date: Thu, 22 Nov 2007 13:10:45 -0500> > The other question would be is the lazer going to pick itself up for read > out when you're doing 65/70MPH. If it was straight out front at a brick > wall sure..but straight down..you may be leaving the rebound info beam > behind. Only one way to find out...> > ----- Original Message ----- > From: "Garry Wright" <wrightdg@davincibb.net>> To: <rebel-builders@dcsol.com>> Sent: Thursday, November 22, 2007 1:04 PM> Subject: Re: [rebel-builders] laser tape measure> > > > Wayne and Walter,> >> > Yes Wayne, you're right about eyes out - I was thinking of a HUD> > arrangement which I also don't know how to rig yet. Walter, after one> > glassy incident I want to load the deck in my own favor if I can without> > spending enough for a moonshot. I think it was you made this suggestion> > - maybe not. What's an AZ pill or am I showing my age - again
?> >> > Garry> >> > WAL
T
ER KLATT wrote:> >> I did?? But sounds like something I could have used a few times...> >>> >> Are you thinking of having that in case of getting caught with an engine > >> out over glassy water?> >>> >> Walter (must not forget to take my AZ pills)> >>> >> ----- Original Message -----> >> From: Garry Wright <wrightdg@davincibb.net>> >> Date: Thursday, November 22, 2007 9:09 am> >> Subject: [rebel-builders] laser tape measure> >> To: rebel-builders@dcsol.com> >>> >>> Walter Klatt suggested the use of a laser tape measure as a low> >>> level> >>> (below 100') altitude device. You can get these at Home Depot> >>> for about> >>> $99US.> >>>> >>> Does anyone know if these tape measures (laser not sonic) will> >>> bounce> >>> properly off water and indicate altitude above the water?> >>>> >>> Has anyone done this?> >>>> >>>> >>> Garry> >>> 068R C-FOKM> >>>> >>>> >>>> >>> -----------------------------------------------------------------> >>> List archives located at: https://mail.dcsol.com/lo
gin> >>> username "rebe
l
" password "builder"> >>> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> >>> List administrator: mike.davis@dcsol.com> >>> -----------------------------------------------------------------> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >> -----------------------------------------------------------------> >> List archives located at: https://mail.dcsol.com/login> >> username "rebel" password "builder"> >> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> >> List administrator: mike.davis@dcsol.com> >> -----------------------------------------------------------------> >>> >>> >>> >>> >>> >> >> >> > -----------------------------------------------------------------> > List archives located at: https://mail.dcsol.com/login> > username "rebel" password "builder"> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com> > List administrator: mike.davis@dcsol.com> > -----------------------------------------------------------------> >> >> >> > > > > > > > ------------------------------------------------
-----------------> List
archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
Are you ready for Windows Live Messenger Beta 8.5 ? Get the latest for free today!
http://entertainment.sympatico.msn.ca/W ... eMessenger
Garry Wright
Hmmm. Overall it doesn't seem like a very good idea. I knew 1 but wasn't
sure about 2. Why do you believe that a flat surface change in mu would
be less detectable than a rough changing surface? I will likely stick
with the proven method. Thanks.
Garry
Dave J
ag
e - again?> >> > Garry> >> > WAL
T
dcs
ol.com/login> >>> username "rebe
l
--------------------------> List
Post by Mike Davis » Sun Feb 19, 2012 4:10 pm
I think there are a number of problems that would need to be addressed.
Even at 70 mph and 10 ft altitude, and that laser traveling at 186,000 mph,
you will still have moved .09322" before the reflection got back to you.
OK, that's only 1/10 of an inch, pretty small movement. But this is
assuming that the laser is aligned perfectly perpendicular to the surface of
the water, and that the water surface is glassy smooth and reflective.
1. Keeping that laser perpendicular to the water would require a gimbaled
housing with gyro stabilization... not really that hard to do now a days
with the small piezo gyros available, wouldn't be too expensive either,
maybe $300 or $400... but it would be unnecessarily complicated I think.
2. Most of these "lasers" in products like this are actually LEDs in the
near infrared range, which unfortunately is almost entirely absorbed by
water... very little reflection.
3. How big is the receiving element on this device? 1/10" at 10', is 1/5"
at 20', is 1" at 100'. Assuming you can point that laser straight down, and
the surface is smooth and reflective, you'd likely need a parabolic
reflector at least 4" in diameter to reliably catch the return and bounce it
into the receiving element. Again, this could be done, but how much effort,
expense, and complication do you want here.
I think with some research, you could find a home made radalt that is much
simpler in design, cheaper to make, and more reliable in operation. Most
radalts operate around 4.3 GHz, compared to the 800 MHz to 1.3 GHz range of
common LED type lasers... so you will not have a problem with your signal
being absorbed/dissipated by the very surface you're trying to measure.
If you're a glutton for punishment, do a search on Hyperspectral imaging to
get a better understanding of some of the above concerns regarding infrared.
Sent: Thursday, November 22, 2007 10:00 AM
Subject: RE: [rebel-builders] laser tape measure
Dave J
T
l
List administrator:
free today!
Thanks Mike! :O)
I did the Canada Wide Science fair in 1976 and the guy beside me in Victoria
was the guy that developed the laser measuring device. It was a box the size
of a TV and had about 6 grand worth of electronics in it.
Sent: Thursday, November 22, 2007 3:38 PM
mph,
1/5"
it
effort,
infrared.
on
Dave J
T
not
l
"rebel"
List administrator:
free today!
[/quote]
Think of a fish tank, you can see clearly through the front... this is
because the light passes through and is not reflected, if the light was
reflected you'd see a mirror... but if you look at the sides from the front,
they look like mirrors. If you go look through the side, now the front
looks like a mirror. Open up the lid and slosh the water back and forth...
you will see shadows of the waves on the bottom. There is a shadow because
now that the light is hitting the water at an angle (waves not being flat)
more light is reflected, less of it reaches the bottom, so you get a shadow.
Funny stuff, and a real pain when making scientific instruments to "look" it
in its various states!
Sent: Thursday, November 22, 2007 10:21 AM
Garry
Dave J
ag
T
dcs
l
[/quote][/quote]---
List administrator:
free today!
[/quote]
mdb1225
Post by mdb1225 » Sun Feb 19, 2012 4:10 pm
The speed of light is 186,000 miles per second..
To:
Dave J
Original Message ----- > From: "Garry Wright" >
To: > Sent: Thursday, November 22, 2007 1:04
T
Garry Wright > >> Date: Thursday, November 22,
l
List administrator:
free today!
[/quote]
Daryl C. W. O'Shea
Post by Daryl C. W. O'Shea » Sun Feb 19, 2012 4:10 pm
17 m/s up north in the winter.
http://www.nature.com/nature/journal/v3 ... 594a0.html
To:
Dave J
T
anyone done this?> >>>> >>>> >>> Garry> >>> 068R C-FOKM> >>>> >>>> >>>> List archives located at: https://mail.dcs
l
mike.davis@dcsol.com> List archives located at: https://mail.dcsol.com/login> >> username
mike.davis@dcsol.com> List archives located at: https://mail.dcsol.com/login> > username "rebel"
List administrator:
free today!
[/quote]
[/quote]
Rick Harper
Post by Rick Harper » Sun Feb 19, 2012 4:10 pm
186,285 mps if you want to be pedantic ! :o)
Biggus
541R
Sent: Friday, November 23, 2007 7:46 AM
To:
Dave J
T
l
List administrator:
free today!
[/quote]
Garry Wright
To all who replied: Thanks for the responses. This thread is done since
no one has actually tried this. I would expect the difference in the
index of refraction between water and air (which is considerable as
witness the bending of a shaft thrust into water at an angle) would be
detectable. The issue of lightspeed is moot as it is so fast that the
aperture of the detector is much wider than the translational movement
of the aircraft at 100 mph.
I may follow up on Mike's sugestion regarding a homemade 4.3 ghz device
but it will have to wait a while.
Garry
Biggus
541R
To:
Dave J
T
l
List administrator:
free today!
[/quote]
[/quote]
Post by Ken » Sun Feb 19, 2012 4:10 pm
Aren't there also cheap ultrasonic based "tape measures". They might
work better than a laser for this.
What I want is a land/water warning. Something like a 2.4ghz microwave
that might be reflected back from land but absorbed by water
Mike Davis wrote:
snip
