murphy-rebel Digest for 11 Jul 2000
Posted: Fri Feb 17, 2012 8:56 pm
I too tried to contact the MAM site last night and a note came up saying the
site was unavailable.
With regards to rivets I spoke to Brian Godden and Elaine and arranged for an
exchange of 10000 rivets. The approach from MAM is that the older rivets will
be adequate on any joint thicker than about .050" and all interior parts
where a mandrel protruding slightly won't matter. The 10000 replacement
rivets are supposedly for the external parts where skins are being installed
and the joint may be only .032" where you definitely don't want to have to
file a head down. MAM state that the older rivets are structurally adequate
and this is the info they also received from their supplier RIVETS UNLIMITED.
It appears that RU have told MAM that the rivets are adequate and as a result
MAM is being forced to eat the cost of the bad rivets we are sending back for
replacement.
So far the AVEX rivets and some 1000 Textron rivets I received from another
source are 100%.
I used a number of CS1213 countersink rivets this past weekend and had a few
mandrels protruding similarly to the RU rivets so it would seem that RU
rivets in general should be avoided for ascetic purposes!!!
Best approach is contact the factory. Arrange to send back rivets. I mailed
mine, cost approx $14 and received new ones within about 2 weeks by mail
Mike Le Ber R683
replacement.
source are 100%.
Mike Le Ber R683
