Dave Jackson
nsubscribe@dcsol.com> LDate: Mon, 5 Nov 2007 08:39:38 -0500> From: klehman@albedo.net> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] To Drill or Not to Drill...> > Craig> The holes are just an easy way to get a round corner with no nicks at > the corner. A straight edge or a rounded corner is desired when bending > metal. A sharp corner or a nick is not wanted.> Ken> > Craig Walls wrote:> > >I thought I read somewhere in the archives that when MAM has you drill holes> >at points where you'll be bending channel/metal, etc, it's just another> >place where a tear could start. In the fin section when you build ribs, the> >directions say to drill holes in each side and then fold them up around a> >piece of wood. Is that a good way or is it better to just make relief cuts> >and then bend? Craig> > > >> > > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-u
i
st administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?w ... &mkt=en-us
