[rebel-builders] Brake caliper orientation
Posted: Sun Feb 19, 2012 4:05 pm
You have to be able to bleed the air out. I only remember a choice of 4
positions but FWIW they fill from the bottom easily in the rear position
without any trapped air. I used a cheap oil can that has a plastic
outlet hose. With the nozzle/tip cut off, the hose slipped over the
bottom fitting.
Jesse Jenks wrote:
bottom fitting.
Jesse Jenks wrote:
The JDM axle brake combo allows for 8 different positions of the caliper in relation to the axle with 45 degrees between each. The Manual, and every picture of a Rebel I've seen, shows the calipers pointing aft. Has anyone tried a different position? I was thinking 45 deg. up from straight aft, or 10:30 on the clock if you were looking at the left wheel from the wingtip. That would get it out of the rocks a bit more.
_
