IO-540
Posted: Fri Feb 17, 2012 8:56 pm
-- FYI --
Just received our July 2000 issue of Sport Aviation - page 144 lists
Lycoming IO-540 G1D5 290HP engines for sale - zero hours since first
overhaul - all accessories and log - no prop governor, with matching
Hartzell constant speed propeller - engine and propeller $19,750 USD,
crated FOB Tucson, AZ no core exchange required - 719-481-2286 fax
719-481-2203
Although this engine is roughly 75 pounds heavier than a parallel valve
engine that MAM uses on its prototypes, it has the added features of
more efficient fuel leaning capabilities, larger diameter crankshaft and
rod bearing diameters, and stronger connecting rods, forged pistons and
piston cooling jets.
If this engine is as advertised, (go over the particulars of the
overhaul with the shop), it's a good buy.
Peter Kopasovic
SR003
719-481-2203
Peter Kopasovic
SR003
