[rebel-builders] floats sealing
Posted: Sun Feb 19, 2012 7:01 pm
The floats were built by MAM with Proseal. Any of the areas that I worked
on, when I stretched them into 1800's, is done with Sikaflex 1A that
can/should be able to be dissolved with Acetone.
The "tank' rivets are RV6402/3/4/5/6. Depending on the length you need I may
have some, or availabe of course thru MAM ...or they should be.
Sent: Monday, October 15, 2007 8:18 PM
Subject: [rebel-builders] floats sealing
Wayne,
Is the grey stuff on FOKM's floats proseal? Either way, what is a
useable solvent to get some of it off - especially at the horizontal
strut/float junctions?
What is the type number of the AVEX rivets for tanks/floats - I think
they do not open on the shop side as much as ordinary rivets.
Garry
PS - I got the yellow things off with about 1 1/2 days of work.
Incredible.
