It wasn't me reporting trouble hearing others in the pattern. It was Ben.
I have trouble hearing others no matter who it is or where they are. Still
haven't figured out my radio noise problem. Sounds like you know a thing or
two about RF. Care to visit Alaska anytime soon?
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of Bill
Maxwell
Sent: Sunday, October 14, 2007 3:25 PM
To:
rebel-builders@dcsol.com
Subject: Re: [rebel-builders] vhf radio
It's not the modulation method, either AM, FM , SSB or whatever, that
determines skip, bounce or reflection from the ionosphere Mike, but the
frequency and therefore the wavelength being used. High Frequency
transmissions do it most reliably but Medium frequencies can do it,
especially at night when particular layers form in the ionosphere. Broadcast
stations in the AM band display this
well, with stations in SouthEast Asia being regularly heard at this location
in Australia.
VHF transmissions, such as those in the Airband, and UHF transmissions do
not reflect off the ionosphere but pass straight through and out to space,
which is how radio communication with satellites is possible. Similarly,
they travel in straight lines at all other angles, including down and
sidewise. They are therefore very much line of sight. The guy departing from
that distant runway cant be heard because he is still on the ground and
there is no line of sight to you. Once he gets airborne though, his
effective range increases with more line of sights opening up to him.
While not impacted by the ionosphere, VHF and UHF transmissions can
sometimes be impacted by a lower region, the troposphere, where the signals
can get trapped and re-directed between tropospheric layers, leading to the
phenomenon known as tropospheric ducting. We regularly encounter this here
in South Eastern Australia in Spring and early Summer, with signals in the 2
meter band, 144 to 148 MHz, being heard up to 1000 Kms away. That is very
close to the Airband.
The other phenomenon readily seen at VHF and UHF is the so-called knife-edge
refraction, where a signal can sometimes be heard on the other side of a
ridge when it is refracted downwards as it passes over the ridge. You can
demonstrate this by shining a torch side on to a knife blade and observing
the light that falls on the surface behind the blade.
There can be a number of reasons for somebody in the pattern with you being
hard to read, ranging through shielding of your antenna by your own airframe
to the strength of the other's nearby transmission simply overloading the
front end of your receiver and producing garbled signals.
Bill
mkimball@gci.net>
To: <
rebel-builders@dcsol.com>
Sent: Monday, October 15, 2007 8:18 AM
Subject: RE: [rebel-builders] vhf radio
I always heard that AM was the kind of signal that could bounce off the
ionosphere. I once picked up a Kansas station in California late at
night.
I've heard that late at night it's more likely to happen but I don't know
why. FM is known to be line of sight. I believe that civilian aircraft
transmissions are AM/VHF.
bransom@dcsol.com
Sent: Sunday, October 14, 2007 11:29 AM
To:
I've always assumed the surprisingly clear reception from far away sources
was maybe due to skipping or reflection. With that, you'd get the direct
line plus the shallow angle reflected. With nearby transmissions,
whatever
goes up/down gets diffused or absorbed instead of skipped. Maybe I'm just
making this up to suit my imagination, but I think about it every time I'm
straining to hear who the heck is on my tail in the pattern and getting
interrupted by the crystal clear busy chatter at airports 60 miles away.
Another look at this is that you never hear those at distant airports
announcing 'taking runway 23 for departure' ...yet they are the same
distance as the surprisingly clear reception. No wave skipping and the
surrounding terrain is like Walter's mountains.
Isn't aircraft bands amplitude modulated? and therefore line of sight and
rather short? If wanting to transmit from mountains or far away places,
at
least to be *sure* of being heard for urgent or serious matters is via
ham?
-Ben/ 496R
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
Unsubscribe:
List administrator:
