[rebel-builders] 360 Prop Elite question
John W
Post by John W » Sun Feb 19, 2012 7:00 pm
Hi Guys any help is appreciated;
I am running a 0-360 on my Elite with amphibs weight
1580 lbs.
I had the 76 Sensenich repitched to 56. I am only
turning up 2480 rpm in climb.
Any suggestions to get to the 2700 for 180 hp
I am often operating at 2200 lbs .
Tks
John W
--- Drew Dalgleish <drewjan@cabletv.on.ca> wrote:
My prop is optimized for best climb and at full
throttle the engine will
over rev.
At 08:45 PM 10/8/2007 -0800, you wrote:
Pardon my ignorance, Drew, but why is running at
full throttle straight and
level at low altitudes hard on an engine?
[mailto:mike.davis@dcsol.com] On Behalf Of Drew
Dalgleish
Sent: Monday, October 08, 2007 9:50 AM
Subject: RE: [rebel-builders] 360 Prop
At 06:27 AM 10/8/2007 -0700, you wrote:
Just another question on the speed, Drew. Have you
done a full power run at
low altitudes and what was the rpm and speed? At
8000, that would be your
max cruise speed, since your engine can't do more
than 75% power at that
altitude.
Sorry Walter I haven't and I probably won't. To me
running at full throttle
straight and level at low altitudes is too hard on
the engine.
List archives located at:
https://mail.dcsol.com/login
____________________________________________________________________________________
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
http://mobile.yahoo.com/go?refer=1GNXIC
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 7:00 pm
I was asking earlier about anyone using the 76 X 56 Sensenich prop on an Elite or Rebel floatplane. If you are only getting 2480 on climb out, then it sounds like you need to go finer yet, maybe to 54 pitch. I don't think you want 2700 on climb, as then you would over rev on straight and level. What is your take-off or static rpm before you go into climb? And what is your flat out straight and level rpm with it at 76 X 56?
My target for the 360 (on floats in a Rebel or Elite) would be 2500 on take-off, 2550 on climb and 2700 -2750 on WOT straight and level.
Which amphibs do you have to get that 1580 empty weight?
Date: Tuesday, October 9, 2007 7:36 am
Subject: RE: [rebel-builders] 360 Prop Elite question
1580 lbs.
Tks
John W
over rev.
Dalgleish
the engine.
John W
Hi Walter
Clamar amphibs
static 2400
t-off 2500
flat out 2700
running a tach check(digital) later today
will retest all above as well.
Tks
John W
weight?
question
weight
1580 lbs.
Tks
John W
over rev.
at
full throttle straight and [mailto:mike.davis@dcsol.com] On Behalf Of Drew
you
At
more
me
on
the engine.
Unsubscribe:
Internet in your
Check out the hottest 2008 models today at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
WALTER KLATT
Just to be clear with my question, I consder take-off (intial) and static as the same thing, and climb rpm to be at your best climb rate speed. Sounds like your top speed rpm is OK.
I forget exactly what 2 inches of pitch gives on the Sensenich. I think it is around 30 or maybe 50 rpm. If that is the case, and your tach is accurate, then 76 X 54 might be what you need.
Date: Tuesday, October 9, 2007 9:38 am
Subject: Re: RE: [rebel-builders] 360 Prop Elite question
Hi Walter
Clamar amphibs
static 2400
t-off 2500
flat out 2700
Tks
John W
weight?
question
weight
1580 lbs.
Tks
John W
at
you
At
more
me
on
Internet in your
____________________________________________________________________________________Check out the hottest 2008 models today at Yahoo! Autos.
Post by Bob Patterson » Sun Feb 19, 2012 7:00 pm
Hi John !
It sounds like your engine is not developing full power.
It should spin that prop faster....
It might be worth checking the size of your carb air box -
there are a few Elites that had O-320 airboxes fitted ...
They are too small, restricting intake, and causing vibration
too !
Other than that, and the usual checks of compression &
timing, you are right to check the tach with an optical one -
again, there have been a few bad tachs found.
If all that checks out, then your only other course is to go
to a 54 inch pitch ...
http://www.prosumers.ca
1580 lbs.
Tks
John W
Robert Andrews
Post by Robert Andrews » Sun Feb 19, 2012 7:00 pm
John,
612e has a bit over 40 hrs on an O-360 swinging a Sensenich 76-54
(76EM855-0-54). Hope to get it in the air soon - have no personal
experience with it yet. Will check the logs and flt test reports for RPM
data this evening.
Bob 612e
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Tuesday, October 09, 2007 10:34 AM
Subject: Re: [rebel-builders] 360 Prop Elite question
Hi John !
too !
1580 lbs.
Tks
John W
Robert Andrews
John,
Found conflicting data in the prop log book ... the model number stamped on
the prop is
76EM8S10-0-56 ... standard prop vs the written number in the log book as
indicated below for a climb prop.
I'll be running on MFC 2200 amphibs, may want to re-pitch it to the -54
(climb) as well.
Still looking for RPM data.
Cheers, Bob 612e
Robert Andrews
Sent: Tuesday, October 09, 2007 6:19 PM
John,
data this evening.
Bob 612e
Patterson
Hi John !
too !
1580 lbs.
Tks
John W
Robert Andrews
Sorry John ... surprising to me, but found no RPM data in the log books.
Bob 612e
Robert Andrews
Sent: Tuesday, October 09, 2007 7:10 PM
John,
the prop is
(climb) as well.
Cheers, Bob 612e
Robert Andrews
John,
data this evening.
Bob 612e
Patterson
Hi John !
too !
1580 lbs.
Tks
John W
Post by Walter Klatt » Sun Feb 19, 2012 7:00 pm
Bob, what cowl do you have, and what size spacer is on the prop?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Robert
Andrews
John,
the prop is
(climb) as well.
Cheers, Bob 612e
Robert Andrews
John,
data this evening.
Bob 612e
Patterson
Hi John !
too !
1580 lbs.
Tks
John W
Robert Andrews
Speed cowl w/ a 2-7/16" SPM8S10 spacer.
Bob
Sent: Tuesday, October 09, 2007 7:54 PM
Andrews
John,
the prop is
(climb) as well.
Cheers, Bob 612e
Robert Andrews
John,
data this evening.
Bob 612e
Patterson
Hi John !
too !
1580 lbs.
Tks
John W
John W
Hi Bob
I checked the tach with a digital last nite.
Static 2350
Climb 2470
WOT 2630
Suspect the airbox as it is small hoping to fit a
K&N style air filter as well
Engine checks out just out of annual.
Last nite flying alone at 2050 lbs 60deg F
lite breeze 5-8 mph 2 seconds on step 10-11 out of
the water. Still room for improvement in rpm's,
needless to say I am thrilled so far.
--- Bob Patterson <beep@sympatico.ca> wrote:
Hi John !
full power.
air box -
fitted ...
vibration
too !
compression &
optical one -
course is to go
weight
1580 lbs.
Tks
John W
Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase.
http://farechase.yahoo.com/
John W
Hi Robert
Thanks for the input. I think I will have the prop
twisted to 54- believe its 37.50 rpms per inch this
should get me 75 on climb.
My logs are at the shop need to check them as well.
How much does your Elite weigh?
JohnW
Bob 612e
Robert Andrews
question
John,
the prop is
(climb) as well.
Cheers, Bob 612e
Robert Andrews
question
John,
Sensenich 76-54
have no personal
data this evening.
Bob 612e
Patterson
question
Hi John !
full power.
air box -
fitted ...
vibration
too !
compression &
optical one -
course is to go
weight
1580 lbs.
Tks
John W
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onese ... fer=1ONXIC
I have also been talking on email to Ed at Sensenich about this, and he
recommends the 54 for our type of floatplane with the 360. He says the 56
should give 2400 static on the 180 hp, and 54 would give 2450. You gain 25
rpm for every inch of pitch.
That's pretty good performance, though, given your weight.
Thanks a lot for the numbers. That helped a lot. Now I have to decide
whether to go 54 or 52 if I go Sensenich. I am wondering what high density
altitude (8000) will do. I think that costs an extra 50 rpm too.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of John W
Sent: Wednesday, October 10, 2007 6:10 AM
Hi Bob
Static 2350
Climb 2470
WOT 2630
Hi John !
full power.
air box -
fitted ...
vibration
too !
compression &
optical one -
course is to go
weight
1580 lbs.
Tks
John W
________
FareChase.
Post by Drew Dalgleish » Sun Feb 19, 2012 7:00 pm
If you removed the air box or maybe even just the air filter and your
static rpm increased that would let you know if the air box is the culprit.
At 06:10 AM 10/10/2007 -0700, you wrote:
Hi Bob
Static 2350
Climb 2470
WOT 2630
Hi John !
full power.
air box -
fitted ...
vibration
too !
compression &
optical one -
course is to go
weight
1580 lbs.
Tks
John W
_________
FareChase.
John W
Gonna check it tonite-
anybody used the Donaldson filter in place of the
Bracket?
air filter and your
Hi Bob
Static 2350
Climb 2470
WOT 2630
Hi John !
full power.
carb
air box -
fitted ...
causing
vibration
too !
compression &
optical one -
course is to go
On Tuesday 09 October 2007 14:36, John W wrote: weight
only
Unsubscribe:
_________
FareChase.
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us. http://surveylink.yahoo.com/gmrs/yahoo_ ... te.asp?a=7
