[rebel-builders] Tire Sources
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 3:57 pm
The way I remember, the ply rating on the tires is indicative of the
load the tires can support. Recalling for a 6x6.00, it was like
4 ply - 1200 lbs, 6 ply - 1800, and 8 ply - 2200 lbs. I suppose that
this varies by manufacturer but the ranges are about correct. So it
depends on the max load your plane will carry.
JBCressman@aol.com
Sent: Wednesday, October 03, 2007 6:12 PM
Subject: [rebel-builders] Tire Sources
Hi There--Am one of the latest "newbies" to join the Rebel crew since I
recently acquired SN 331. Attended the meeting in Brampton last month and
met a
number of you. I gained much valuable advice and learned that sources for
tires for Rebels were scarce, so went searching. My Rebel is on MAM amphibs
thus
I was
searching for front and main tires.
I found the following: Front tires--Carlisle 2.80 x 4 in a 4 ply with tube
available through a wholesale
distributor in Montreal for $25 (for both) through Ken Dillabough of
TIRECRAFT (613) 432-9955 or
800-711-4511 These tires and tubes are exactly what was on 331 when I
purchased her. Ken is located
in Renfrew, Ontario and a very helpful guy.
Main tires---Cheng Shin 11.400 x5 8 ply rated available through the new
Aircraft Spruce store 1760
Meyerside Drive, Mississauga 905-795-2278 or 877-795-2278. I bought 4
tires and 4 tubes for $134 and change. I cleaned out their stock and
required a
Back Order but their computer showed 302 tires and 302 tubes in their
California warehouse. Again, these tires are exactly what is installed on
331. I have
no news on tires for wheel only gear as I do not know the sizes. I would
check Aircraft Spruce first on that need, however. Bob Cressman
Post by Craig Walls » Sun Feb 19, 2012 3:57 pm
Man!!! I wish I were looking for tires for my amphibs instead of getting
ready to pull the first rivet!! Ha Welcome, Bob. Craig Walls R207
JBCressman@aol.com
Sent: Wednesday, October 03, 2007 2:12 PM
met a
thus
I was
required a
331. I have
Post by Drew Dalgleish » Sun Feb 19, 2012 3:57 pm
# 207 and you haven't pulled the first rivet? Man that's a long time to
take inventory.
JBCressman@aol.com
met a
thus
I was
required a
331. I have
I counted each rivet.
Dalgleish
Sent: Thursday, October 04, 2007 6:30 PM
Subject: RE: [rebel-builders] Tire Sources
take inventory.
JBCressman@aol.com
met a
thus
I was
required a
331. I have
