Gearbox lubrication
Posted: Sun Feb 19, 2012 6:56 pm
by Mike Kimball
All of the oil leakage is out through a vent at the top of the redrive.
Luckily the vent is a modified hose barb fitting the gearbox manufacturer
supplied so I can hook a tube to it to go to a catch can. I ran the engine
for a short time with the return line sitting in a catch can instead of back
to the engine and oil was moving freely through the return so it's not
plugged.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of LeRoy
Taylor
Sent: Monday, September 24, 2007 3:14 PM
Subject: Re: [rebel-builders] Radio Noise
I have a Ross drive with very very little leakage. It is restricted on the
inlet side like yours . Could your outlet side be plugged to where it
forces the oil through the seals. ,or could your seals be bad. Leroy
To: "Rebel Builder's List" <rebel-builders@dcsol.com>
Sent: Monday, September 24, 2007 4:57 PM
Subject: [rebel-builders] Radio Noise
I've finally gotten to the point where I can fly my plane regularly now.
have an issue with the oil system for my gearbox. I made the mistake of
supplying oil to the gearbox from a pressurized source from the engine.
At
60-70 psi I am giving the gearbox too much volume, even through a 1/16
restriction. I lose a quart of oil in 30 minutes in flight out the
gearbox
vent. I temporarily rigged a catch can for this so I could keep flying.
should have taken oil from an unpressurized source (i.e., the oil pan). I
am going to switch to a dry sump for the gearbox this winter.
Despite that, my biggest problem continues to be radio noise. Can I
enlist
the help of you other auto conversion folks? Can you tell me about your
ignition and radio setup? What kind of spark plug wires are used? Are
they
shielded? I assume your ignition is electronic HEI of some sort. Mine
has
an electronic ignition module that sends a low voltage pulse to a standard
automotive coil which then sends the high voltage pulse through the
distributor to the spark plug. (Stock MSD stuff.) My radio is grounded
at
a grounding block that is attached to the firewall and the engine via a
large diameter grounding cable. My alternator is not the problem. I have
run the engine with the alternator belts detached and still have the radio
noise. I have filters on the radio power cables and the ignition module
power. Any ideas would be greatly appreciated.
Checked by AVG Free Edition.
Version: 7.5.488 / Virus Database: 269.13.30/1027 - Release Date:
9/24/2007 11:27 AM
