For many years, Murphy has specified the use of Polyfiber Epoxy Primer,
EP-430, and the hardener to go with it. All parts must have this brushed on
between joints, then assembled WET. Rivets are also dipped in it before
inserting & pulling - again WET ! Many builders have been very happy
with this. Several have used other products - personally, I'd use the
Polyfiber - it's a few more $$, but well proven... just MHO !
Might be good to visit a Murphy builder nearby to learn best practices
and techniques - there is a good intro on the Murphy web site under
Tech Support....
The rivet gun is a PULLER - just put it on the rivet mandrel, push
hard so the rivet is in place, and pull the trigger. You can practice
on some scrap pieces ... Be sure to protect your eyes - especially if
there's no mandrel trap on the back of the gun !
http://www.prosumers.ca
On Friday 14 September 2007 22:53, snowyrvr@mtaonline.net wrote:
Hi Gang,
Apparently epoxy chromate is no longer available. The aircraft stores up
here say it was deemed too dangerous and are carrying epoxy primer instead.
Anyone used this? Probably the same thing as E.C. Also, anyone know of or
seen a good guide or instructions to using a rivet gun? I have two now
but have never used one. Thanks in advance. Craig
