[rebel-builders] Rebel -final drilling wing bolts
Posted: Sun Feb 19, 2012 12:16 pm
Hi Jesse !
I guess you know that you have to make up a spacer to
fill that large gap on the front wing attach fittings ...
some have machined a chunk of aluminum to have a tab
extending to hold - in effect, a very thick-walled tube with
a small side handle - others have just stacked washers &
epoxied them together. Some have also machined
Delrin to fit - but it's a bit soft for the job...
The spacer is to fill the gap and prevent the bolt
from crushing the tabs, when tightened.
http://www.prosumers.ca
On Monday 20 August 2007 02:46, Jesse Jenks wrote:
I have had my wings on temporarily once to get everything aligned and build
the struts. I used undersized bolts, and planned to drill everything to
final size at a later date. Now I am wondering if I should reassemble and
drill the fittings while mated to ensure proper bolt to hole alignment, or
if I can drill/ream everything separately. Doing it assembled sounds
better, but I don't know how I would keep everything from moving while
drilling. For example, if I remove the bolt from the front wing attachment
then how do I immobilize that joint while drilling? There is a large gap
between the fittings, and so no way to clamp them tight. The rear fitting
and the struts may be easier because they all have a close fit, but still
seems a bit harry trying to keep it together with no bolts.
